Quick update of this weeks rust removal / paint stripping / cleaning progress.
Pic of the heavy brackets that hold the brake/clutch pedal assemblies. I think (if I remember correctly) the two smaller pieces are for mounting the steering column.
The two smaller pieces looked just as bad as the big piece before I started to clean them up. I do not think these pieces were ever painted at the factory. There was no evidence of paint found anywhere on these pieces, the big piece anyway.
And almost ready for paint.
I also have been working on prepping the pedal assemblies for paint. I forgot to take before pics, but these parts were not in as bad as shape as the above pictured parts. I had alot of paint to strip from these pieces. I used the "Aircraft Stripper" in a can that is found at Auto-zone. Works pretty good, I had to re-coat two to three times to get the pieces to this point. The flat piece pictured is the mounting plate for the rollover check valve and the liquid check valve that mount up inside the drivers side rear corner of the body.
I bought a can of this stuff at Auto-zone.
Now, I don't usually believe that these types of products would work. It only cost $8 so i figured that I would try a can. Surprisingly, after leaving a few smaller parts to soak in this stuff (completely submerged) overnight, I was amazed to see that it did remove the rust. Now, to be fair, I had removed all of the super heavy rust off these parts with a wire brush, but this stuff did remove the rust from all the hard to get to nook and crannies plus it completely removed all the light rust from the pieces.
Close up of a part that soaked in this stuff for 10 hours. You can see how the liquid is a rusty brown color, plus the bottom of the pan is covered in rust flakes. The black stuff remaining on the part is old paint that I still need to remove.
If only I could afford to fill a swimming pool with this stuff I would be in business. I will probably buy another can of this stuff so that I can soak a few more small, hard to clean parts.
I also removed the pulleys and fan from the engine so that I could clean and paint them.
Pics of the engine without the above mentioned parts. Since the rest of the engine is clean and painted i couldn't skimp on these parts.
Still more cleaning and painting to do. That's it for now.
