reassembly
after spending a few weeks of intermittent days working on topcoating the frame, I've finally started to get some focused progress going... with some comically bad decisions along the way..
I had a neighbor help me move the frame out of the garage so I could topcoat my axle housings and then "rebuild" all the brakes/hardware in anticipation of setting them up, and then moving the frame back on top of them..
got the axles topcoated and ready for assembly and started laying out all my brake parts, and then reveiwing my manuals/photos when my eyes happened to brush across the words "parking brake"... and I'm sure glad it made me stop to think, "huh, when in this sequence do I reinstall the e-brake cables..?"
turns out they're the FIRST thing you feed back through the backing plate, and without (a) them ready or (b) anything for them to fasten/hold on to, I had to call the neighbor back over to move the frame (again) back into the garage and start assembly, sans brakes..
next error.. ordered the "classic tube" stainless brake lines to re-plumb the chassis before the body goes on.. didn't look closely enough at my order before I clicked "pay", and got the wrong set delivered to the house.. Quadratec helped me out with a shipping label to return them, but still had to order (and now wait) for a second set, which they claim will take 3-4 weeks to get here..
I won't bore you with a thousand pictures of things that I bolted back on, as Raymond's build thread is much more detailed, and I can tell you he expended MUCH more energy and attention to detail than I did.. I've been doing much of the same style work though, with a combination of sandblasting and wire-brushing stuff, followed by spray paint, and then installation..
bottom line: I've loosely assembled the front/rear suspensions, the steering links, most of the frame bolt-ons, PS gear box, front brakes, and a few odds/ends
for BW.. no Yuengling tonight..
Some lessons and observations
- spent about 80 bucks on graded and stainless hardware to replace rusty/ugly original stuff on the chassis, and still came up short a few items.. figure closer to 100$
- was using "what came off" as the reference for "what to buy", should have gone item by item through the FSM and see how it was REALLY suppossed to be mounted
- a fully assemble front axles is HEAVY, but I was able to manuever it in small doses using a ratchet strap over my back and legs to lift, but I scratched the hell out of my freshly painted leaf springs doing so
- my front axle dropped right onto the index pins on the leaf springs, BEFORE I realized I hadn't put the steering stabilize mount on
- front and rear spring shackles on my Superlift 2.5 inch lift use different lenght bolts, which I didn't remember from installing it back in 2006, found out the hard way (had both front shackles with one mismatched bolt each) and had to do a front/rear bolt swap on each side
- my rear axle did NOT fall right onto the index pins on the leaf springs, and it appeard to be about 1/2 inch too wide for the springs, solution: fully install one side with spring plate and u-bolts, and then pull the other spring outboard by hand (had my feet on the side of the diff for leverage) and get the other side of the axle to pop down over the guide pin.. not sure if this is an effect of the "frame narrowing" without the center skid plate in, or just "manufacturers tolerances"
- I found myself constantly thinking I needed to "remember to do X" later... bottom line; recommend you have a notepad close by to jot down the hundreds of "little things" that pop up as you go, I've been incredibly frustrated with my own lack of organization and inefficiencies..
what's next: still workig on a few bolt-ons, going to start resourcing more of the "plumbing", which is a bit trick (especially when it comes to decision on fuel lines, since I'm doing a 4.0L swap on this install), have to re-seal the front/rear diff covers, clean and reinstall the fuel tank, and start cleaning/ordering parts for the 4.0L install, since the motor is functional, but dirty (and needs the CPS, VSS and other adapters to work on the CJ harness)
