- Biloxi
- MS
Thanks, and thanks for spotting the winch. I can see the completed version in my head of the whole Scrambler. It's going to be sweet. I should have the tub back this month.![]()
This month, which year
This month, which year![]()
The shocks are mounted correctly. For Bilsteins, that is. Most shocks mount rod up, Bilsteins, Edelbrocks, and most other high-end shocks mount rod down.
What color and paint system are you using?
Just curious, 'cause looking at the pics I was pretty sure you and I have the same paint color & scheme. But what I originally believed was Sebring Red actually color codes to Oriental Red.
Second question about the paint system stems from Gary's $997 per gallon for red. Didn't know if that was PPG or what type, but scary none the less.
Not sure if it is true but I heard you could mount Bilsteins either way.
What happen with the painter? Quality? Time? Looks like he sprayed the base coat on most of it.
I'm told no real painter will want to paint over his prep work and still warranty the job. So far it's just time wasted b/c he did more prep work than what I originally paid him.
Thats a real bummer, I feel your pain. I painted mine myself. it came out pretty good and if I were to do it again I know it would be even better. BTW, I'm only 15 miles away in Gonzales
