Scrambler on a budget
its dash time :woot:
and a nice day to do it on. soon ill be driving it on these beautiful days.
i ground the paint off an put a ground wire that will go directly to the battery. i read so many dash grounding nightmares.
then i removed the PO crappy wiring, it was BAD! this is some of it
its awkward getting it on without scratching it so i used towels a sponge and a box to keep it in place
i ran out of time and light was fading so i'll finish it up later. i know there are some gremblins in there
I love that color. I would prefer you put a crimped eye on that ground cable though.
i got a bunch of parts in over past few days
valve cover, gaskets and grommets. got a good deal from fellow jeeper MKNIGHT759 arrived as promised no surprises
i just hope it doesnt leak :popcorn::popcorn:
i also need an alternator so i figured out how it works. thanks to youtube.
tore it down and it was the original one. it had a lot of corrosion on the stator
the carbon brushes were shot and the bearing was about to seize (it was screaming)
i found a bearing that fit it buried in my tool box :woot::woot:
i took the carbon brushes out of an old central vacuum i had lying around, filed
them down to fit in the holder. soldered them in. i polished the stator and then
re-assembled it. tossed it on and :cheers::cheers::cheers:
this 65 amp unit will have to go at some point to make way for a 100+ amp unit; but for now on a budget this $0 cost repair will work fine.
Most...impressive...poor-man's fix...EVER. That's the stuff my old neighbor Clarence would do back when he was alive. If you didn't have it, you couldn't afford it, so you made it.
i had alot of electrical issues ie: grounds and an ign. switch plug that wasnt making contact.
so after 2 days of screwing around with that, the dash is 95% finished.
the radio was trashed by the sand blasting and i have to open up the speedo and volt meter to get the sand out of them. not fun :banghead:
the oil pressure sender was full of oil and i decided to install a mechanical SW gauge. i have had this gauge in a lot of my cars. i got it when i was 16 or 17 yrs old :rotfl: remember never throw anything useful away!!!!!!!
this engine pushes 80psi when oil is cool
painted up my winch mountings
a few more setbacks
the LR axle bearing after 200 miles or less destroyed itself. i think it was ether the ARB lockers thrust block wasn't letting the bearing seat enough, or not thick enough of a shim to preload it.
i thought that grease would protect metal from rusting WRONG!!!!.
that grease that flings off from a leaking seal and lands on the tub; REMOVE IT!! it seems to hold in the moisture once it destroys the undercoating.
i didnt have a before but here is after scraping off the old grease
sprayed in some rubberized undercoating 3 more to go
the bed liner was next. i used dupli-color with teflon. i used it first in the cab and seems to hold up ok
here is with the first coat
the bumper that came with it wasnt the correct one so i did a mod to it. now it has 3 large bolts and 3 smaller bolts holding it on the jeep. when i got it 2 small bolts were holding it on.
ground off all the rust and painted it. came out pretty good
i mounted 2 fire extinguishers next to each seat. i couldnt think of anywhere else to put them.
next week the hood fenders and windshield will be done, cant wait :D
thanks for the positive remarks :D
well i got more GREEN parts today :woot:
man do i love the cj fender look, nothing else compares for me
i never had a vehicle this old and this clean
ARB compressor mounted up
now i need to lookup the best way to install the glass after i pick up the seal
here is the bed with both coats on it
tomorrow the hood!!!!!
I tried that... once.. and broke my glass. I then took the route of taking it to a local glass place which (a) can do it and (b) warantees against leaks, which you might find useful in the future if you want to re-gasket it on their dime. It may not be as hard as it looked to me, but it's certainly not a forgiving material to work with. :twocents:
hoods on :woot:
all inner fenders are rubberized. now all the little parts need to be painted next.
CANT WAIT TO DRIVE THIS RIG !!!!!!!
i started on the roll bar today, and i noticed my garage is lookin like i can put my car back in there :D
the decal was next. i was sweat-in on this job. if you have a long decal and its on a curve you have to snip it every 4-6 inches or it will buckle and look like siht.
the LF fender and hood are done inside and out!!!
the pass side needs some wire management done when the winch gets installed
lastly today i put back the tonneau cover cleats, i understand they are wider than the normal ones
Your "sweat-in" on the decals turned out well. Looks great
thanks guys
i cant believe how good things have turned out.
its been 1 year since i got it, and never imagined i would have a jeep this nice.
