Well here the idea.....I have a very built CJ7 with rust issues. I'm going to need to replace a fair amount of the lower part of the tub and parts of the floor. Knowing that the Cj7 and the CJ8 is exactly the same from behind the front seats forward and one can get all of the body panels at places like this....
www.trailquest.com/body-parts/cj8 .....I thought, "What if I just ordered the CJ8 panel....hummmm?"
What started this idea was that fact that I also have another clean straight post 82' CJ7 frame. I have a good friend that owns a autobody shop. So using his frame machine I plan to cut my CJ7 frame and the spare CJ7 frame so that it adds 10 inches and there is only one patch point with a fish plate.
I agree with you guys that swapping parts over from a CJ7 to a CJ8 is easier, however finding a CJ8 rust free for under what it's going to cost to do the mod's to my CJ7 is a ton harder then one would think. Besides even if I found a CJ8, it most likely need the very same thing, maybe even a frame...
So you all know what I'm working with.....I've built my CJ up over the last ten years. I have a cut down Dana 60 front narrow Dana 70HD rear, both with 5:13's and ARB's, Heavy duty ARB lines, custom drag link and tir rod made from solid chrome molly hydraulic ram rods drilled and tapped. Custom Alcan 2.5" lift SOA designed leaf springs with anti wrap, M.O.R.E. prototype SRS, motor mounts, front bumper, crossover shock hoop, slip lock trac-bar, and anti wrap bar. It has a custom exo-cage like a Rover D90 to protect the windshield and top, ARB snorkle, on board York air compressor, Premier Power welder, dual batteries, separate charging systems from Wrangler Products that can be tied together, Tuffy boxes, AGR ram assist steering, IPF 145 watt H4 head lights, custom rear tire carrier and bumper, ungraded 20 Gallon fuel tank, switched from 4 spd to a built bombproof TF999 and Dana 300 with Tera low 4 to 1, Great lakes indexing ring and bullet proof deferential covers, custom CV shafts front and rear, custom tummy tuck transmission crossmember, full underbody skid shield, custom 5/16 side slider rails....there's more but I just cannot think of now....
I built the Jeep before I had children. Now that I have 4 girls, I need more room for the trail runs. I planned on building up one of my FSJ wagoneers or Cherokee's, but a lot of the parts on my CJ won't swap over. By stretching the frame and adding another row of seats, I can kill two birds with one stone. Keep my CJ and take the family wheeling!
The avatar is a picture of my CJ on 39" IROKS and a link to a bigger picture is in my SIG.
