NEWBE question
COLOJEEPGUY2K
Chaffee County
co
I did some searching and couldn't find anything. Has been a discussion about "making a CJ8 by stretching a CJ7? Any ideas, pictures, or links to threads about this?
I have not read any discussions on this site about it, but have seen a lot of projects that are based on that idea. I also found a guy in Florida who is selling, as a Scrambler, a CJ8 body on a Chevy Blazer frame. It doesn't look so good.
But, I have seen a few CJ7's converted to longer wheel bases and some look pretty good. I think the Scrambler gets the proportions right, but I think I have seen even longer ones.
What I don't get it buying a CJ8 and then bobbing it. Why not just move the axles out on a CJ7 or 5?
anything is possible, but I don't see the point in all the effort and expense over just finding a Scrambler. If you have a -7 built, all the good bits swap over, sell off the rest of the -7 or build a functional vehicle out of the take off parts from the Scrambler.
Just my :twocents:
Or sell the CJ7 and buy a Scrambler! I believe Adam H on here is attempting that right now.
Is a lot less work...maybe...depending on the Scrambler you buy.
I did just that, several reasons were i already had the scrambler and it was evolving over the years and seeing much more trail time, i couldn't afford to buy another jeep and i got tired of beating the crap out of the back end of the scrambler so i bobbed it and quit dragging the tail and getting hung up on things. The scrambler also alllowed me to streatch the wheel base even more than i could on a cj7 and still keep it leaf sprung, my current set up has the front axle moved forward 2" and moved the rear back another 6" so i'm sitting at 8" more wheelbase than a stock scrambler, it works well for me and i'm happy with it. I do have another scrambler i'm working on that willl remain a tail dragger have no plans to cut or chop on it and it will be a driver not a toy. To answer the other question yes you can stretch a cj7 and make them as long as you want and as many seats as you want, but it will still be a cj7 and not a scrambler, i've seen several done that were very nice rigs.
It can be done.
I have seen where a CJ7 frame was stretched into a CJ8 by adding exactly 10 inches to the straight section between the second and third body mount and then the third body mount was moved forward 10 inches. Then to complete the frame they added 13.98 inches to the rear and then welded on a cj7 cross support and there it is a cj8 frame.
As for the body you would need to change the rear end of the cj7
Differences between the 7 and 8 are the bed floor length with its supports, corner floors, upper and lower gussets which support the roll bar front, roll bar of course, second to last floor support which is what the roll attaches to in the back, wheel tubs and the outer rear skin as the wheel openings are elongated and not round.
to finish it you would need the bulkhead and half top. there you have it a CJ-7.8
Or, start with a SJ Cherokee/Wagoner frame, section the frame down to 104"+/- and go from there. Mr. Beep built "Franken8" that way. You get Dana 44s front and rear, an AMC 360 and maybe a T18/NP208 in the bargain.:evil:
Or buy a TDK frame and an aftermarket Scrambler tub and make your own by moving everything else over from your 7.
I'm curious about this build, I guess MrBeep is a member here? Is there a build write-up?
I mounted my tub on my 79 Bronco frame and running gear but just went back to the original CJ-8 frame to put it back on the street.
It can be done.
I got in an 8 with more cracks, damage, and rust in the frame then I was comfortable with and decided it wasn't worth repairing or keeping it. So I took a Cj-7 frame with a bad rear section and another CJ-7 frame with a bad front section and merged them with 2x4 3/16 steel tube. Used the rear extensions from the old frame and took dimensions off another good 8 frame that I had for another Jeep. Moved 4 mounts total and while it was a bunch of work, it turned out nice. Most who see it cant tell it was two frames.
Sorry the pics aren't in order, but you'll get the idea.
Well here the idea.....I have a very built CJ7 with rust issues. I'm going to need to replace a fair amount of the lower part of the tub and parts of the floor. Knowing that the Cj7 and the CJ8 is exactly the same from behind the front seats forward and one can get all of the body panels at places like this.... www.trailquest.com/body-parts/cj8 .....I thought, "What if I just ordered the CJ8 panel....hummmm?"
What started this idea was that fact that I also have another clean straight post 82' CJ7 frame. I have a good friend that owns a autobody shop. So using his frame machine I plan to cut my CJ7 frame and the spare CJ7 frame so that it adds 10 inches and there is only one patch point with a fish plate.
I agree with you guys that swapping parts over from a CJ7 to a CJ8 is easier, however finding a CJ8 rust free for under what it's going to cost to do the mod's to my CJ7 is a ton harder then one would think. Besides even if I found a CJ8, it most likely need the very same thing, maybe even a frame...:D
So you all know what I'm working with.....I've built my CJ up over the last ten years. I have a cut down Dana 60 front narrow Dana 70HD rear, both with 5:13's and ARB's, Heavy duty ARB lines, custom drag link and tir rod made from solid chrome molly hydraulic ram rods drilled and tapped. Custom Alcan 2.5" lift SOA designed leaf springs with anti wrap, M.O.R.E. prototype SRS, motor mounts, front bumper, crossover shock hoop, slip lock trac-bar, and anti wrap bar. It has a custom exo-cage like a Rover D90 to protect the windshield and top, ARB snorkle, on board York air compressor, Premier Power welder, dual batteries, separate charging systems from Wrangler Products that can be tied together, Tuffy boxes, AGR ram assist steering, IPF 145 watt H4 head lights, custom rear tire carrier and bumper, ungraded 20 Gallon fuel tank, switched from 4 spd to a built bombproof TF999 and Dana 300 with Tera low 4 to 1, Great lakes indexing ring and bullet proof deferential covers, custom CV shafts front and rear, custom tummy tuck transmission crossmember, full underbody skid shield, custom 5/16 side slider rails....there's more but I just cannot think of now....:smokin:
I built the Jeep before I had children. Now that I have 4 girls, I need more room for the trail runs. I planned on building up one of my FSJ wagoneers or Cherokee's, but a lot of the parts on my CJ won't swap over. By stretching the frame and adding another row of seats, I can kill two birds with one stone. Keep my CJ and take the family wheeling! :fingerscrossed:
The avatar is a picture of my CJ on 39" IROKS and a link to a bigger picture is in my SIG.
I was in a very similar situation in terms of having a somewhat built CJ-7, and not wanting to deal with another rusty CJ. I had a (galvanized) YJ tub on mine, making me less inclined to want to cut the tub, and really it was the rusty 7 frame that prompted my project. My solution: TDK frame, and an Aqualu tub. Initially, I figured the only thing I really needed to buy was a rear drive shaft, and new brake/fuel lines. (Let's just say the concept expanded before I even began the build.)
Sure, it'll probably be more work doing a complete frame swap, but you'd get the Scrambler you need without the patch job.
Good point however I've seen frame extensions performed correctly and are as strong as the factory frame was. I may be shooting my self in the foot by trying this but I've planned it and looks on paper as it will be more cost effective! We'll see????:thumbsup:
