Fuel injection....Is it worth the money???
project 8
Nacogdoches
TX
Hello,
New to the forum and would like to get some opions on fuel injection for a 4.2.
Pros and cons, all replys welcome....
Thanks
Well, through precise metering of fuel your not washing down the cylinders and causing more wear on your engine. It can run at an optimum burn without leaning out too far and burning pistons, therefore you gain fuel mileage and performance. I really like to tune carbs but with fuel injection it constantly does it for you.
Welcome
First off WELCOME.
Depends on what your plans are for the Jeep. If you are planning on wheeling it and keeping it long term, the injection will well be worth the investment.
I noticed your home town. Gary & Debbie Nix are from there also and are long time members here. They have a very clean Scramblers with fuel injection. :thumbsup:
:wave:
First off WELCOME.
:wave:
You beat me to it. Find Gary & Debbie. Just watch out for their mules. I'll bet they kick.
I have the Howell on my 258 and love it. Get in, turn the key, go.
Welcome....and Yes! It's worth it, it makes it far more driveable.
Drivability is awsome. Nutter and MC2100/Weber are great improvements, but nothing compares. Make sure the 258 is sound before you buy a new EFI kit. Otherwise, a 4.0L donor vehicle and part out may make more sense.
Basically what he said. For total simplicity on a near stock rig that won't get wheeled hard, I'd do another Motorcraft 2100 with an HEI setup in a second. For anything with bigger tires and/or harder wheeling (more incline/sidehill) I'd go Howell FI on a good 258 or swap in a 4.0 (which is what I did).
Ultimate goal for me is a stroker based on a 4.0 mating with a 258 to get the low end torque of the 258 and the driveability and upper end power of the 4.0 while running on pump gas :evil:
I found no difference between the motorcraft and TBI in a daily driver; in fact I liked the MC much more and, especially in the winter, it ran a lot better with my engine. Mainly because I have a non-cooled manifold without a heater, and in the cold weather the TBI runs like crap until the engine and manifold are at op. temp. With a manual choked MC, I could dial it in no matter what the outside temp.
Bottom line: I like the TBI, it was costly though easy to install and hasn't given me (much) trouble since, but if it weren't for emissions guidelines in CO, I wouldn't have installed it and instead stuck with the MC.
I've had a few CJs and a mildly built (4", 33s) FSJ - all with carbs, 2 and 4 bbls. ALL sucked on the trail. On the street, they were great. Aside from 3 cranks, and 4 minutes of warm up, the FSJ ran like it was fuel injected... until I pointed the nose up a steep climb - sputter, cough... plewwww....stall.
Current build - actually the reason for the current build - is a 5.7 SBC with First Fuel Injection (TPI). I spent more on just the intake system (intake, computer, injectors, harness, throttle body, etc.) than any of my previous Jeeps (initial purchase). Crazy huh. Decided to build that "last" one... you know the "keeper". Sure... ;)
Fuel injection
Thanks for all the thoughts on FI. I am going to keep the Jeep long term so I took the advise and ordered the Howell kit this morning. I have meet Gary a couple times and heard some crazy stories about the mules and going the the hospital while on a hunting trip.
Thanks again
Brian
Thumbs Up
Good choice! Now all you have to do is get it installed and tuned in before the Nationals so you can follow Gary and Debbie to join us in MO in June! :thumbsup: ;)
:wave:
