crash
Mad Scientist
- Gold BAr
- WA
Ok finally got what I wanted---damn thing is still going to be tight due to the lack of room on the passenger side.
Here is the main mount I started with at the t-case
This took some figuring because I needed the tube to also dive forwards on the passenger side--but I finally got it bent where I wanted it to.
When you work alone and your damn picky--you always figure out creative ways to jig your stuff up
And finally tacked into place.
So I got it pulled back out tonight and buzzed the tube to the main mount. I also added on support on the back side and started building the front support/ramp. Hoping a couple more evenings and I will be ready to pull the trans back out to prep the frame rails for the x-member mounts.
and they will also be a place for shocks to mount (to be later figured out).
