The little flatty--for a lil fella
Ok finally got what I wanted---damn thing is still going to be tight due to the lack of room on the passenger side.
Here is the main mount I started with at the t-case
This took some figuring because I needed the tube to also dive forwards on the passenger side--but I finally got it bent where I wanted it to.
When you work alone and your damn picky--you always figure out creative ways to jig your stuff up :D
And finally tacked into place.
So I got it pulled back out tonight and buzzed the tube to the main mount. I also added on support on the back side and started building the front support/ramp. Hoping a couple more evenings and I will be ready to pull the trans back out to prep the frame rails for the x-member mounts.
So after a bunch of work I finally got the crossmember/skid built.
Bolted up to double check final fitment :awesomework:
Since the t-case had a nice mount on the side one thing I fought in my design was trying to incorpurate that into the cross member and still have room for the mount at the frame. This should add a bunch of strength.
So now that the center of the cross member was done it was time to work on the frame side. Marked my locations and then pulled the tranny/t-case back out.
Again I sat there on my back inhailing OLD rusty dust (yuk) and made plates. I ended up counter sinking the plates 1/8" inboard of the edge of the frame rails. I did this for a couple reasons.
The first being the body sits directly on the frame and there is a layer of metal on top/bottom of the frame with rust in etween it and would make for a VERY pourous weld. So I was able to get a good weld between the plate and the main portion of the frame--ok it welded good but doesn't look good (IMO). I also chose to do it in this manner since the tubework is tied into the frame like it is that should minimize any flex to the frame/ causing it to tear apart (like you see).
So I got the tranny back in and started on the crossmember mounts when I ran outa steam.. But I am getting there...
I finally got the brackets cut and the mounts made.
Then got the tub notched and mounts welded to the cross member.
Then I was able to get the brackets tacked in place and pulled the tranny back out. Once out I burned the mounts in and threw some paint on them.
Then came a fun part--pulled new parts out of the boxes and threw all the clutch stuff in--was nice to have everything bolt up/fit as it should.
So back in the tranny went. This time was a little more of battle with having all the clutch stuff in it--but she went finally...
So I threw the new x-member in and finally its stilling on its own weight..
I have to pull it out again so I can drill a couple drain holes and throw paint on it once I get new bolts for it. But it really did turn out nice and the fitment is dead on.
SO next I went and started throwing all the stuff on the front of the motor so I can get the cross tubes done up.
Nice, Crash! I see I wasn't the only one working on a cross tube today...
you are an excellent fabricator Crash:bow::bow::bow::bow: I've done some in my day but thats just plain GOOD.
Hey guys..
First thanks for the kind words......
I haven't been here in a bit and wanted to let ya'll know I am still alive and kickin. I am slowly trying to get back to some sort of normality and finally getting back into the shop.
I will get this build up to date as I have allot more that has been done since my last post...
Good to see you back here, Crash. Been wondering how you're doing.
That might very well be the sexiest trans/t-tcase skid/mount I've seen to date.
Outstanding work sir. Well done. Love it.
Fully enjoying this thread.
What Jake said. :thumbsup:
:wave:
So what I wanted was some support for the fenders as there is none to a side hit. I also wanted more places to mount things under the hood if need be and also front sock mounts since with the wider housing the stock ones will no longer work.
So I came up with a game plan and finally started bending more tube.
The weakest point on the fenders is about 3/4 down the fender from the grill bar but I could not run a tube across--too many things in the way.
So this is how I gave some support to it.
I got it fully welded in and now I gotta make tube plates and cut the tubing/weld then in so of course the tube can be removed.
I have 2 more down tubes for the shocks and a little more for the radiator once I get one.
So I was able to chomp thru some more and I think it will all make sense for ya here dale :D
Mark and chop a section of tube out.
I like to do one at a time with just tack weld the parts in place. Once all for the needed tube is in place then I buzz each one in.
And there ya go...
As suspected there was a little pulling/pushing on tube from the welding process--but very managble when installing/removing the assembly.
And now the motor can easily come out. The only thing I overlooked was the clearance on the bolt plate near the brake assembly. The tube itself easily comes in/out with the brakes in place but its very tight removing the brake booster.. I also got the down tubes/shock mounts bent up but I ran outa steel mix gas....
I had some time and looked it over and found I can get a couple other items done prior to the rad.
I got the PS mount modified and fitted.
I got some more plates burned and welded onto the frame.
Bent a couple pieces of tube/cut/notch.
These will serve 2 purpose's. First giving more support to the bashable fenders. If dale gets mad he can jump up/down on the fenders (:redneck:) and they will also be a place for shocks to mount (to be later figured out).
