Crazyredneck87
- Pomeroy
- WA
Ok, Ever since we did the Spring over Axle Conversion. Anytime I get up to 50 mph or higher the entire Jeep feels like its shaking apart. Though it feels like the front end is sliding side to side. I have replaced all the wheel bearings,All the U Bolts are extremely tight (reefed on em with a cheater bar to eliminate them).Front Drive shaft is off as well. I just took it in for an Aligment and still is doing it. I aint sure what is going on. Though I did notice the front driver side is sitting a bit lower got to looking at it and the spring perch is sitting higher on the passenger side not sure if this would play into the issues. Tires are good to go as well had them checked out as well they best be they are brand new tires.
So I am coming to yall for some insight on this. Its driving me up the wall. My neighbor whom also is a jeeper couldnt figure it out either. So I am hoping someone here has had the same problem.
Specs on Tires are Mickey Thompson Baja MTZ 35 12.15 15s.
Dana 30 Front.
Dana 30 Front.
