Lets see your Garage/Man Caves!!
If you have a Windows machine, right-click on the picture then select the "Open With" option. Then select Microsoft Office Picture Manager. It has an edit button on the toolbar you can crop or resize easily with it.
Hell I still can't figure it out.
I think I finally figured it out. Anyway Here are the pictures of the ceiling going up in my shop. You can see how the vinyl cover is seperating from the insulation. Oh, the basketball goal is legal highth
White white white white. Only color for garages in my book. When I painted our garage in NC white I was FLOORED how much of a difference it made with the same lighting.
There is no doubt the lighting makes a big difference but I was thinking gray so it wouldbe easier to keep the wall from looking
dirty. I have 5 8ft DBL fixtures in each bay or a total of 60 4 ft T6 tubes. But youhave me thinking white again.
How about this, since my walls are 16 feet tall I could do the bottom 12 ft in gray and the top 4 ft in white.
Most of the dirt comes from the floor... I think it would look really good with the bottom 4' gray and the top 12' white. An added advantage is if you ever have to replace a lower panel due to an impact, it would only be a 4' piece. Most damage occurs on the very bottom anyways.
Aesthetically the darker (heavier) color always belongs on the bottom. At least that's what my wife says...
As the old timers on here know, I had a 40x50 shop in Texas that I posted pics of on a similar thread 9+ years ago. When I moved to TN I had to rebuild it just so I had a place for my crap and cars, etc.
The pics below show a couple shots of it before I got the Blue Lakewood wagon in the 4th pic. There is one pic showing the lift prior to getting the wagon. 40x50 ain't enough for 3 cars, a motorhome and all the other crap a person accumulates over the years. ;)
The best thing I have ever gotten, other than a shop is the lift. :bacon::bacon: Will not crawl under a car ever again, if I can avoid it. Sorry for the big pics!
Ed, where is the engine located in that first one? (Blue one)
I've decided...The bottom 8ft will be Rustic red which nearly matches the color of thesupport beams and the top 7'5" will be white. This should work good for dirt and hand prints on the bottom and lots of reflective light on top.
Interesting...I don't know how I feel about red on the bottom. (not that it's my decision) Is there the possibility that the reflected light will change the hue of perceived color? Sort of like a white car takes on a pink hue when parked next to a red wall? That's going to be a lot of dark red.
I'm still a fan of the white above gray. You could really "spice" it up by doing a 4" red stripe 4" above the gray...
Anyways...Pics when it's done, of course!:thumbsup:
If you look at the way my shop is laid out you can see that most of the Rustc red will be behind tool boxes benches and storaage cabinets
so much of it won't be seen. Also it won't show grease and dirt as bad.
i might would lean towards the grey as well... another random comment: ever thought about adding plywood as a liner panel to a height of 8' then install the metal panels above? we install 3/4" plywood in a good majority of the buildings we build that fit your application..get a good sanded side t&g plywood anchored to a treated shoe on concrete and screw the plywood to the 1st purlin which should be at 7'4"... throw a coat of paint on it and boo-yow. unlimited, easily anchorable, space for shelving units, shelving, cabinets,etc...good solid flush surface thru-out the shop. paint it any color if you dont like it , change it. will accept paint a lot better than r-panels. not to mention, not likely to dent a piece of 3/4" plywood vs a metal liner panel. ..paint bottom of plywood one color, add an accent stripe near where metal ties in... who knows ..possibilities are endless....
I can see that. Looking at the pics it would actually make the tool boxes "stand out".
Scrambled Eggs' plywood idea is a winner too. I've always had sheetrock on the walls...sucks putting up shelves and those miscellaneous hangers that you always need to place between the studs...
I like the idea of plywood too but I'm to cheap to do it and I'm too lazy to do all the painting. The ceilings are just about complete and I have ordered the material to do the walls.
Here's an update on the shop/garage. All the ceilings are complete and I have half the walls complete. So far I'm very pleased with the colors I decided to go with. Even though when I built my shop I installed a total of 30 electrical circuits I am still taking this oportunity to relocate some of them. Remember my shop is also my home so thats the reason for so many circuits. pardon the mess, it's a work in progress.
