New To Me 83--Parts Needed
Knocked a few more items off of my "Yard Scrambler to do list" this weekend.
I finally secured the hard top. I just had to screw the front of it to the windshield. I also installed the upper seat belt bolts/bushings correctly. The hard top is now very secure, no rattles or "lifting off the front edge" anymore.
I cleaned and re lubed the old speedometer cable. I used powdered graphite for lube. I installed the cable and the speedometer works. It actually works pretty good, really smooth with no "bouncing". The speedo is off, though. I am using the stock 28 tooth gear that was originally used with the 2.72 gears and 235 sized tires. Since "Yard Scrambler" now has 3.31 gears, the speedo is showing a higher speed then reality. Once I put new tires on it, I will recalculate and put in a closer to correct speedo gear.
I am still waiting for my new dash board pull cables that control the heater functions. I was able to clean/re lube the cables that are part of the heater box, and now they work nice and smooth. once I get the dash board control cables, all of the heater/vent/defrost functions should work. I also installed a new flexible defrost duct.
I played around with the timing, I now have it set around 7 degrees BTDC. This Scrambler is really fun to drive. We really lucked out with this used engine. I believe this engine has a mild cam, due to a slight "lope" at idle. The engine fires right up, and pulls really hard throughout the usable RPM range. I also installed/hooked up the choke, and it now works. I need to do a bit more adjusting to the choke, but it is working.
I also played around with the gauges. I replaced the fuel and temp gauges with another used set i had. The fuel gauge is now functioning, but the temp gauge is not. I believe I need to swap back in the old temp gauge, that was functioning.
All of the above really wasn't picture worthy, so here are some shots of the interior, which I have not really shown before.
Picture from the rear, showing the ubiquitous stock CJ "uneven seat syndrome". I also scrubbed all the glass, inside and out. I used "Invisiglass" glass cleaner, scrubbed with newspaper, worked really well.
Picture through the driver side window. All of the old green slime that was on the glass is now gone.
And some general interior shots. I really like the Sherwood green/nutmeg combination. None of these interior pieces are in perfect shape, they all have minor cracks and splits. They match the general "patina" of Yard Scrambler well IMO.
I was trying to show the inside of the hard top in this picture. I didn't clean it before i installed it, so it was pretty nasty/dirty/mildew/moldy/funky. I used some "Zapp 505" all purpose cleaner I bought at Home Depot to clean it, and it worked great. Spray on, wipe off, finished.
After taking these pictures, I went to roll the driver side window down and it fell to the bottom of the door. Luckily, it didn't break. I pulled the interior door panel off to see what happened, and found this:
The little plastic insert that snap into the holes in the glass popped out. I guess when the regulator was broke/froze up, and people were forcing the window up and down, it damaged these pieces. Luckily, I have some spare glass in my garage so i had some extra plastic retainers.
It never ends..................
I drove "Yard Scrambler" around Saturday night, put about 100 miles on it. So far, it is working great. I am going to get the alignment checked, I believe it is slightly "tow out", but it still drives straight, no shimmy or pull. The brakes and steering work great, the new clutch functions great, and it shifts up and down through all the gears fine. The engine preforms great, it is really fun to drive. Even the old used suspension/shocks work well. The suspension has just the right mix of "soft yet firm", if that makes sense. All in all, the whole Scrambler feels "solid". No rattles, squeaks, clunks, bangs, ect. To be really "nit picky", it does have a very slight vibration when you are accelerating really hard in the lower gears, but I believe this is a slight u-joint angle issue. The replacement rear axle had the perches welded on at a slight angle. It is not enough for me to worry about fixing. I put about 50 miles on it with the speedo pegged at 85, which is actually closer to 75 MPH, and the Scrambler performed flawlessly. I might try to get new exhaust/tires installed this week. I plan on taking it on its first road trip next weekend, about 200 miles away.
That's it for now.
Getting tires and exhaust installed Friday, Yard Scrambler will be ready for Boggs and Boulders ORV park this Saturday :headbang:::wave:
Might put a winch on it, too:fingerscrossed:
You need a patina SE 8274 to go on that thing.....surely you have one of those sitting around for just such an occasion.
Taking "Yard Scrambler" on its first "long" trip tonight. I have to meet Tommy in Mandeville, LA (about 1/2 way between Biloxi and Baton Rouge) to pick up the last of the parts I need, plus drop off a bunch of left over parts. It's probably about 80 miles each way, not too long, but the first "extended trip" for Yard Scrambler since its been back up and running. I put about 50 miles of city driving on it at work today with no issues, so it should be good to go. I got it aligned yesterday, in advance of "new tires/exhaust Friday".
Just one quick picture.
Going to pick up a "goody" for Yard Scrambler tonight, should help out all the JK's I am riding with on Saturday:rotfl:
That's it for now:wave:
Well, "Yard Scrambler" successfully made it's first "long" trip. It made the trip to Louisiana and back to Mississippi successfully. I drove between 70-75 MPH with no issues. It drove nice/smooth/stable and did not miss a beat. My only minor complaint - it has a very slight "dead spot" with the wheel at center. It does not drift/pull/feel loose, but there is about 1/8" of slack off center in each direction. I believe most of this slack is caused by the wore out lower steering coupler shaft. Its not a big deal, but I can feel it. My red and green Scramblers are both tight on center, so the slight slack is noticeable to me. Most people would think its how they are supposed to be LOL.
A few pictures.
"Yard Scrambler" making it back to the "motherland" for the first time in a couple of years, it's "Homecoming" LOL. Picture doesn't show it, but that blue sign is the "Welcome to Louisiana" sign.
Kind of blurry, but "Yard Scrambler" with the speedo pegged. It's not really going that fast, 28 tooth transfer case gear/235 tires/3.31 axle gears is not the correct formula. It shows about 15 mph too fast. A 31 tooth speedo gear is needed with this combo, but the tire size swap will negate this, so I will wait till I get the new tires installed and then figure out what gear I need.
And the new, "JK Extraction Device", Warn 8274 with factory brush guard. I still need to mount the brush guard center piece, two small bumper angle brackets, wire up the winch, and re-spool the cable. We will call this a work in progress for now. If anyone has any pictures of a CJ with an 8274 with factory brush guard, please post them up. I am still trying to figure out a few things.
I think the winch and brush guard really make Yard Scrambler look "mean". The small white walls look out of place now, but that will be fixed tomorrow.
JeepAddict got a chance to drive Yard Scrambler for the first time last night, and I think he was pretty happy with it, too. I will let him post up his impressions.
New exhaust and tires tomorrow, and a few quick interior upgrades Friday night, and then mud city on Saturday:drool:
Man this Scrambler is sweet. perfect off road vehicle for me. I could even leave it parked at walmart with the doors unlocked and not worry about it. Went from 0-85 in about 4 seconds too. Atleast that's what the speedo said. Great Job Spanky!:bow::bacon::headbang:
:wave:
Think that's "bienevenue en Louisiane" ;)
Looks great, love the retro grill guard.
You are correct:thumbsup::wave:
The OEM brush guard is slowly growing on me. It will look even better once I install the center hoop:)
I dropped yard scrambler off late yesterday at the shop, new tires and exhaust today, can't wait to get it back, it should be much quieter, plus new tires are always cool:smokin:
Can't wait for Saturday, with all the rain we have had lately, old yard Scrambler is going to get a work out in all of the "wet dirt":rotfl::cool:
And of course, the adventure continues:crazy:
While "yard scrambler" was at the 4x4 shop getting new exhaust and tires, I told them to go ahead and change the rear pinion oil seal that had a slight leak. Well, after pulling the pinion yoke and inspecting it, there were several cracks in the yoke:eek: I was able to purchase a new yoke at another store and bring it there for installation, saved the day:D
A few pictures of yard scrambler up on the lift. Sorry for all the dirt, it was super clean until I started driving it to work everyday.
General picture:
Missing yoke:
And the new exhaust. In keeping with the "budget", the shop had a used Magnaflow that had been installed, kept a few days, then removed when the owner didn't like it. We got a pretty good deal on it, so that's whats on it.
That's it for now..........................................................
Time for some pictures.
Some boring parking lot shots, with the new 32x11.50x15 tires installed. I thought they were going to rub, but they only barely hit the flares when the suspension is really crossed up off road. I believe it currently has old, wore out 2.5" springs. If it were mine, I would add a new 2.5" lift, but the current set up does work.
Friday night, before the Saturday trip, I installed the following:
new heater control cables
plastic glove box
factory center console
factory spare tire carrier
hooked up/tested the winch
One quick "night before the first ride picture".
The factory spare tire carrier/rear bumper do not work perfect together. The bottom of the tire hits the bumper, the wheel does not sit flush against the mount for the bottom lug nut. I tightened the top two lugs, hand tightened the bottom lug. With the carrier shut, the tire does not rattle or move. Not the best solution, but it works. Need to add a swing away tire carrier to the current bumper, but for now, it works.
A few more boring parking lot pictures.
A quick driving down the highway picture, I love the hood decals.
When we got to the park, everybody was flocking around Yard Scrambler like paparazzi to Lindsay Lohan LOL.
Up next, some action/post action shots.
And a few more fun shots.
And this picture about sums it up, "Yard Scrambler" is a blast!!!!!!!!
After all the fun in the mud, took about 8 hours to clean up "Yard Scrambler". Even though it is just "Yard Scrambler", I cleaned it up as good as I clean my red Scrambler. It is spotless. Some picture of the once again "clean" CJ8.
The once again clean bed, with mismatched paint color.
Clean interior, with matching center console.
A quick "after action" report. Yard Scrambler is a blast!!!! It drove great on the highway, did great off-road (even at severe inclines with a Carter BBD), over all, a great, fun jeep. On the approximately 140 mile trip from Cedar Lake Road to Exit 83 off I65 in Alabama, it burned 8 gallons of gas. That is 17.5 MPG at 70 mph. Could not ask for much more. The winch worked perfect, never used it on Yard Scrambler, but it pulled out the Grand Cherokee a few times.
For all the good, I did have a few minor issues.
The fan clutch hit the radiator a few times. It did not hit deep enough to leak, but a two core radiator needs to be installed to prevent this from happening in the future.
The body mount bolts got loose. I think this is more of a "need to recheck tightness of all bolts after the first 500 miles of driving" thing. I lost the two front bolts, found one. Luckily, I did not lose either of the lower bushings. It is just missing in the picture. I plan on re torquing all body mount/suspension/power train bolts this week.
Not really a "problem", but I did manage to dent the transfer case skid plate pretty good when I tried to take it on a "big boy" obstacle. A small suspension lift will prevent this from happening in the future.
The factory steering shaft has too much play for my tastes. The jeep tracks straight and true, but in a strong cross wind, the slack in the lower coupling is annoying. An upgraded steering shaft would be a great investment, especially considering the locking front differential.
I still need to address the "poor idle" condition. I believe I have a vaccum leak, no big deal.
All in all, for a Jeep I built in the yard, I think "Yard Scrambler" turned out great. A few more minor fixes, and it will be even better.
I will be sad to see it go.........................
