New To Me 83--Parts Needed
You're my hero ;). My 8 has been sitting motionless at the new house (for one year this month) with only a few things left to get it on the road... And no progress. New home, new job, two kids , and MBA via night school are some of my excuses... As they say, there are no excuses, there are only reasons.
Great job! I really like the "well used" look it has. I would put an original black bumper on the front and some good used fender flares and drive it every day! I even like the white wall tires!
Especially the white walls! :bacon: :headbang: :wave:
I'd DD that!!! Nice work Raymond! Now get to work on the V8 Scrambler for the Sandblast!!
Nice Raymond! :thumbsup: :wave:
Appreciate it Toby !!!
It even spins out on dry roads, 235's with 3.31's are the bomb :headbang:
I'ms still single, no kids, lots of Scrambler time. You, on the other hand, have your hands full:cheers:
Got some used flares, wish I had a black bumper, maybe I can paint this one......
Looking good!
Appreciate it !!!!!!
The white walls are pretty dry rotted, but I will keep them on for a little while longer........
You aint kidding!!!!
Appreciate it:thumbsup:
A quick little "Before and After";
BEFORE
AFTER
It still pretty much looks the same, which is what we were going for. But, underneath, it has been rebuilt;)
This has been a bunch of work, more then I initially thought, but then my anal retentiveness crept into some of it:crazy:
I will say one thing, I don't ever want to rebuild one (as in depth as this one went) out in the "yard" again:thumbsup:
In a way, I am glad this one is about finished (for now), but I will miss it when it eventually goes back to JeepAddict:(
You've probably already addressed this but, any intent to buff out that original paint? Looks like it may be salvageable in this pic...?
...............................................................BEFORE................................ AND.............................................AFTER
fixed it for you.
you do really sh!tty work!!! That Scrambler was mint before you started!!! :rotfl:
With a bunch of elbow grease, the existing paint could clean up, some. It will never "shine", it is too far gone/faded. It is pretty thin in spots, too. I hand buffed a part of it, and it actually cleaned up pretty good:shrug: The decals, would be the biggest hindrance. In order to buff it out, you would have to masking tape over the decals to keep the machine from shredding them, they are pretty toasty:eek:
It could clean up better then how it sits now, I will wash it one of these days. But, I will leave the buffing/waxing to JeepAddict:popcorn:
Looks sweet man! My favorite pic is the empty spot in the yard where it sat for so long during the process.
You convinced me to let you bring this Scrambler back from the dead instead of parting it out and using some of the parts for my now dead, your next project, SL restoration. Congratulations! Can't wait to take it off road. :headbang:
Also, paint revival and probably black front bumper in its future.
"We have the technology, we can rebuild him................":rotfl:
Instead of the "The 6 Million Dollar Man", more like "The 6 Thousand Dollar Scrambler":rotfl::rotfl:
PS - NO MORE YARD SCRAMBLERS, unless their mine:crazy::crazy::rotfl::thumbsup:
Since "Yard Scrambler" is now mobile, I have been able to move it close to the house so that I can work on it at night.
I wasted a bunch of time trying to filter out the ps fluid. I used an in-line diesel fuel filter/water separator set up:
I mounted it on the return line. I left it hanging below all the ps stuff, to make it easy to drain. You can just make it out in the following picture:
And after an hour of running, and two "drains", I was still left with a milkshake:
I finally just started running motor oil through the system, and two more quarts of fluid, finally got the water out. Water in the ps system sucks. In hindsight, I should have just changed the box and pump, I spent about 1/2 that amount in ps fluid.
After getting the water out, I finally put the correct ps pulley on. The Chevy truck one on the left, the smaller jeep one on the right:
I also installed the passenger seat. One of the little metal inserts that the seat bolt goes into was rusted out. I ended up using some "Sonic Weld" two part epoxy stuff and filled in the damaged area. Surprisingly, it worked. Probably not the safest thing in the world, but judging from how the factory metal insert are foamed in/held in by the thin metal straps, not much worse. It is only one hole, the rear inner insert closest to the seat belt latch, so i am not too worried about it. If it does break, the weight of the person in the seat coupled to the fact that the seat belt will squish them into the seat, should be OK. The other three inserts are intact. One out of four isn't terrible.
I also installed the fender flares and a rear bumper. Starting to look "complete".
I also put the rear view mirrors on, hooked up the power brake booster (it still works) and installed the air cleaner.
I still need to get the gauges working, then I will start driving it more often/longer trips. I have been driving it around the neighborhood, and it drives really well. The engine seems pretty "spunky", it accelerates rapidly, and all in, runs really wells. The steering is good and tight, the brakes work well, even the suspension seems OK. It just has the old "Detroit Locker" clunk, which after going to selectable lockers, seems pretty archaic.
That's it for now.
What's the total budget (ballpark) in this thing now? I know you had most of the parts laying around, but still curious.....
Not as cheap as we wanted :rotfl:
JeepAddit = $2,500
$1,500 - original purchase
$ 550 - all stainless steel lines (fuel/brakes)
$ 450 - used engine
Spankrjs = $3,700 and some change, still going............:crazy:
Total Cost = $6,200
That does not count the following, "big ticket free parts": AMC 20 rear with Detroit and Yukon axles, Dana 30 chrome moly 44 sized super shafts, free centerforce stage 3 clutch kit, rebuilt T176/Dana 300, carb and intake and ignition from my old Scrambler, numerous free doodads I had as leftovers.
Sounds high, but the $3,700 from me is every can of paint, every nut and bolt, every new part I had to buy. I really kept up with it. It is kind of shocking when you add up receipts:eek:
Could we get $6,200 for it if we sold it, probably not. But, could we buy a rust free Scrambler (except bed floor/windshield frame) with a completely rebuilt power train, locked front and rear, with upgraded shafts, and countless new parts, for $6,200, and know it was "done right", probably not:twocents:
Once I get the gauges working, this Scrambler will be 100% functional. Every light, gauge, electrical item, and mechanical component will work as intended. While she is a little shabby on the outside, she's got it where it counts:twocents::thumbsup:
After adding up my receipts for this project, I know I will never add them up for my red Scrambler:crazy:
