Engine Swap fuel issue. Please help!
kryptoniteCJ8
Houston
Tx
I'm in the finial phase of my SBC swap. But I'm having a problem picking up fuel from the tank. My setup is as follows
1981 CJ8 GM 2.5L I-4 (Removed) fuel line on passenger frame rail.
1970 GM SBC 350 (Installed)
New Mechanical fuel pump
New holley 650 DP Mech. Secondary's
All New rubber lines, fuel filter, regulator.
New sending unit in tank
9-10 gal of fuel in tank.
My issue is this after starting it,it runs great. But within minutes it starts starving for fuel. The only thing I haven't replaced is the hard line on the frame. I'm thinking I'm gonna run rubber line from the tank to the pump to try that. Any ideas guys?
I'm guessing it's a stock mechanical fuel pump, right? I've never needed a pressure regulator on one of those. Might be an issue. Try bypassing it.
Is your mechanical pump a 2 fitting or a 3 fitting? Trying to remember...Ahhh..found the picture. Mine was a 2 fitting (no return). Did you connect to the feed line not the return at the frame rail? It's the larger of the 2 lines. Might be a bad fuel pump too...
Did you remember to remove the long bolt that you used to hold the fuel pump pushrod in place, and replace it with a short one? If not the cam would push the pushrod down once and it wouldn't come back up, and the pump wouldn't pump. Don't ask how I know...
Or maybe the fuel sock (filter screen on the in-tank pickup) is clogged.
It sounds like you're burning through the fuel in the float bowls and then starving out.
I am using new 2 port pump so no return line. I'm almost 100% certain that its hooked up correctly. I have a new sender and sock-->new rubber line to old hard line --->old hard line-->new fuel filter @ pump on suction side-->new mech. Pump-->new regulator--> to new holley 650 dp. I'm out of ideas. I can see a little fuel in the filter just before the pump(maybe 1/4 full) . I also don't have the other hard line hooked up to the evap canister. Does any one have a diagram of how the fuel tank and evap system and roll over stuff are suppose to be Plummed?
The original GM I-4 2.5 only had two hard lines one for the fuel and one for the vent to the evap canister.
Heck your clamps on the suction lines. I had this happen on mine with. Sbc350 and it would idle but starve for fuel. My clamp was loose on the rubber line at the fuel pump inlet side.
Do you have a fuel filter between the pump and carb? If so discount and see if you have fuel.
Replace the pressure regulator with a clear fuel filter temporarily. See if there's fuel being pumped.
Is this the initial startup? Takes forever to prime the lines. I cheated- disconnected the line at the pump, put a rag around my blow gun, and "pressurized" the tank through the fill neck until gas came out the line by the pump. If you do this, be careful.
What kind of regulator? A picture of it would help. I once had an adjustable one that after a minute would shut off all fuel to the carb.
What brand fuel pump are you using ? if you are using one of those cute looking clear filters get rid of it ! use one of the old fachion steel filters and last dont put a filter on the suction side of the pump,put it between the pump and the carb !
kryptoniteCJ8,how are you making out ?
Ive been working on it slowly.
Right now I do have the clear fuel filter on the suction side. The pump is a adv. Auto parts stock mechanical pump, And the Mr. Gasket fuel press reg on the pressure side. I'm going to remove the reg. And put the filter on the pressure side. Once I'm satisfied that the fuel system is working properly I will put a metal filter in place. What I have found out is that if I remove the gas cap the pump has constant fuel. But I also have a problem with the secondarys on the holley 650 dp dripping fuel at idle. So I'm going to pull it and readjust the float again to stop the secondary drip that is causing the motor to run really rich at idle. Any ideas why its pulling a vacuum on the tank?
On a good note I took the wife and daughter on a joy ride around our neighborhood last sat which was fun and the wife said that the new corbeau Baja rs were very comfortable but the side pipe exhaust stinks (because its running rich at idle due to the secondary drip.)
Let me know what you guys think!
I've had old fuel line separate internally and suck shut on the intake side of the pump.
Sent from my BlackBerry 9700
I've been told the stock hard fuel lines are too small to adequately supply a V8. Classic Tube sells a larger diameter hard line for SBC conversions.
It sounds like you have your float levels too high or the fuel pressure too high. If you have a stock pump, you should not need a regulator.
I'm guessing float level too high. If you have too much pressure, you can try a late 80's Wagoneer fuel filter, it has a return fitting on it that you can hook up to the stock 2.5 return. It would go where the regulator is now.
The stock metal lines should be OK. I ran my 350 on them for a couple years.
You need a way to release the vacuum in the tank- do you have the 2 small vapor hoses hooked up correctly, or just looped together? You can always get a vented gas cap...
