This is what I am running on the front of my red Scrambler. It is an expensive option if all you are looking to do is clear the factory center caps, but it is way stronger then any bolt on hub set up
And that just bolts on to the dana 30 setup?
I have to say, I am intrigued for the CJ7 wheeler I have.
The Scrambler is already converted to 6 bolt, so I am not going back, but the CJ7 has bolt backing out issues as you have stated.
It uses the stock spindles, hub seals, wheel bearings, brake calipers, everything. You just put your rotors on, and it bolts right up, no other modifications/part swapping needed.
It also comes with much better wheel bearing retainer/adjusting nuts. No more bend the little tabs.
I ran these on my 78 for 10 plus years, well over 100,000 miles, no problems. They are still on the Jeep today. And that was with a V8 and an auto-locking differential. I never even had to re tighten up the wheel bearings
The cost seems high, but how much are a pair of Warn bolt on hubs, around $200
I have a set coming for my V8 '84 project, one less thing to worry about
