I bought another scrambler !
Someone went through a lot of work to mess up that jeep.
at least the welds look good and clean... what was that guy thinking!!!!
Oh and I found out that the Dana 60–2 has 4:10 gear and a trac loc, while the front axle has 331
Sent from my iPhone
Okay, that will be much commentary just a lot of pictures, should be self-explanatory
Sent from my iPhone
Wow, I know you trailered it home, but did you at least drive it around the parking lot once to see how it handled set up like this?? It was a once in a lifetime chance...
Body , frame ,dana 60-2 (57") and the new Kayline top was worth what I paid for it
I bought it knowing I had to change it, and I have all the parts to fix it
I did drive it around my neighborhood and it drove fine but it's crap
Sent from my iPhone
Was trying to use this 77 Wagoneer box
But don't have what I need due to shaft size
So I'm using a box and shaft from the 84 triple Blk I bought this summer
Sent from my iPhone
On the driver side, two of the three nuts in the frame were broke out
Had to drill and tap the broken stud in the third
That sucked!
So, I drilled two holes with holesaw in the frame to access and hope to just re-weld these areas up
Sent from my iPhone
Good to see that junk coming off. Weld a nice fishplate over the holesawed area after filling and grinding the patches smooth.
