I bought another scrambler !
Bolted box into place
Welded nut to frame. ( my buddy Scott )
Welded it shut. !!
Sent from my iPhone
Got the new rear hangers from quadratec
I tapped the frame where the original rivets were to position hangers exactly where they should be
Opened up the hanger holes
Bolted hanger inter place
Sent from my iPhone
Good to see it being done the right way. You have been a round a few jeep frames before!
The marriage is complete... very cool... although the pinstripe is reminding me of the pinstripe on mine... must be brothers from other mothers.
Thanks all !!!
Didn't have any front leaf-spring shackles
So I cut a set of rear shackles down and picked up some grade. 8 bolts from Lowe's
Oh and front springs are four-inch lift rough country from 86 Laredo I parted over the summer
Dana 30 from same jeep, 4.10 ratio
I will be installing the same 4 inch springs in rear along with 86 Dana 44 -4.10 ratio
Saving rear Dana 60 for another hopefull project
Sent from my iPhone
Not a lot of progress today
Existing brake line brackets hung to low sent to close to swaybar
Went over to Scott's yard and source some OEM brackets to fix it correctly
Sorry about the picture quality, my iPhone is having problems focusing, no upgrade till May
Added some brake lines that I also sourced from the 86 Laredo
Sent from my iPhone
Ok. , I'm close
I just need to find Power steering hose for a. 80-81 cj7 with amc 304
Sent from my iPhone
