New Scrambler owner!
jmac743
Seymour
TN
I just recently purchased a 82 scrambler for project vehicle. I am looking for some help trying to find correct parts to make it look original. Does anyone know of a company that has catalogs or a website that deals in correct products. I have been looking for a scrambler for a long time. I am excited about getting started and will get a few pics up soon. Thanks for any help that can be given!
Welcome to the forum! You won't find a better source for CJ8 information, anywhere - I can guarantee you that! We may be the best resource for correct products, so don't hesitate to ask!
X2. Maybe not me personally, but there are some real experts on this forum. It is a godsend.
Welcome and congrats, looking forward to seeing your project progress!
Welcome and congratulations!
In terms of "correct" parts, that depends what you mean. That could be different things for different folks. Lots of options for reproduction stuff for most parts but if you're really talking original as in stock parts.
Can't wait to see what you have.
2
Looks awesome! Any plans to lift it? I'm not sure how much more original you can make it, other than some wagon wheels and smaller tires if you don't plan a lift.
It's got provisions for the roll bar-mounted spare, which looks way cooler than a rear-mounted spare, so maybe an original roll bar spare holder? Front bumper looks good (even if the push bar isn't stock - it's maybe an old aftermarket piece and I like the look), rear bumper isn't stock but looks good.
Not sure what else you can do - does it have seats? Original seats can be found if you're patient.
Nice looking Scrambler! You don't see too many white ones especially with the stripe kit. There are lots of little things you could do to make it more stock appearing: OEM wagon wheels, original style tires, side steps, side view mirrors, rocker trim, Marchal fogs, OEM rear bumper, wood side boards (would require drilling both the roll bar and the tub as it looks like yours never had them from the factory). Also, it is hard to tell but it looks like the hood hardware (side latches, and windshield tie downs) are not original so those could be swapped for original ones. I'm sure there is little stuff you could do on the interior too. Not that any of that stuff needs to be done, it is very nice as is, it all depends on how close to stock you want and what original accessories you want to add. Make it your own!
It has some minor body work to be done, engine tuned, sending unit for the gas tank needs to be replaced. Would like to fine some original doors and eventually paint. Its in very decent shape but needs some work. I think I found a great one for a project vehicle. Going to fix some minor issues first. Got some good ideas, but they will have to come later. Cant wait, I feel like a kid a Christmas!
Thanks. The guys i got it from added the stripes about two days before i got it.
So eventually you plan on ditching that paint - or is the current paint job getting old? To find the original color, check the vin badge on the firewall near the master cylinder. Under the vin is a bunch of number/letter combinations. "5EB" or something like that will be your paint code.
The doors are YJ doors but that don't mean a thing - you can drop the door-mounted rear views, throw on some windshield mounted rear views, and be as good as new. YJ doors didn't differ structurally from CJ doors, at least after '80. At some point in 82 they switched over to vent windows, which yours probably have.
A black tonneau cover would be a nice add to this. That and a Warn 8274 winch!
Nice! Looks like a great starting point.
On the sending unit, is it because the gauge doesn't work? If so, lots of times it's a grounding issue at the gauge.
Has anyone had issues fixing/replacing the signal light switch? Just wondering if it is something I might be able to handle or not?
The turn signal switch in the steering column? If so, yes. That is the very first thing I did. Not hard at all. I followed some instructions I found online for replacing the lock cylinder. Once you get the wheel off, things just start coming out in order. Just be careful with the wiring harness going down through the column. I almost screwed mine up by putting a bolt back in with the wires in the way.
