Another Adams Family Scrambler build (moderate trail rig)
CHIEFWAHO
SOA VP
SOA Board Member
Thayer
KS
Using part of stock XJ air box to adapt to a K&N filter
Awaiting the K&N and a custom standoff bracket
Plat to use K&N cone filter RU-5122
Oh, we did have it running.
Lot's of small stuff to finish. Hope to drive by end of week.
Test run scheduled for May 11, finger crossed.
If we meet that deadline and all goes well, it will head to Moab for the last week of May!
CHIEFWAHO
SOA VP
SOA Board Member
Thayer
KS
Got the flat fenders back from powder coating!
attachment.php
attachment.php
attachment.php
Bad Karma
Captain Sarcasm
BENEFACTOR
Member
Cobourg, Ontario, Cana
da
what did you use to wrap the exhaust?
CHIEFWAHO
SOA VP
SOA Board Member
Thayer
KS
Didn't like how the winch solenoid box covered the turn signal.
So pap did a nice little mod to move it more center to clear turn signal.
4.0L computer and fuse box nicely attached to fender, along with ARB compressor for front locker.
Checking out the dash wiring.
Rocker skids mounted.
Pap fabbed up a nice bracket for clamping the K&N filter in place.
bigwalton
Alaskan Postal nutjob
FORUM MANAGER
Dexter
I have the older version of this shifter that integrates the 1st gear lock and LOVE it, perfect in the dunes or anytime I want to feel like a Ferrari driver popping between gears with the flip of a switch:
http://www.radesignsproducts.com/Rail.html
You can also wire in the torque converter lock and I made a spot on my mount for the switch to do it, but honestly I couldn't figure out when you'd want to lock it out enough to justify doing the mod. Open to your thoughts on that one.
bigwalton
FORUM MANAGER
Dexter
I sense that this isn't your first build.... Making it look to easy.
I seriously LOLed at that :rotfl:
Not sure if anyone anywhere has built more Scramblers than has come out of the Adams clan :bow:
53D Scrambler
Hampstead
NC
Are you using a 77-82 Corvette Master Cylinder? I had heard that they are a decent upgrade to the stock master cylinder....I ask because I keep buying NEW ones from the parts store and the lids keep leaking, looks like a better lid design.
CHIEFWAHO
SOA VP
SOA Board Member
Thayer
KS
No. It is the Navajo brake kit from Off Again 4x4. http://www.offagain4x4.com/Navajo_brakes.html
This was used unit we acquired. The master cylinder was bad, the guys at Off Again said to use master cylinder from a 1978 Chevy 1 ton
O'Reilly Part # 10-1534
CHIEFWAHO
SOA VP
SOA Board Member
Thayer
KS
It lives, running and shifting pretty good.
Trying to figure out shocks and bump stops.
forum
