What did you do with your Scrambler today? August 2013 version
Sad day; loading all the jeep parts into Old 94. All the jeeps and parts are up for sale, including the M100 trailer. Have a guy coming over tomorrow to pay for my beloved CJ5.
a>
Saturday I hauled mine 270 miles home on a trailer. Yesterday I got to hear it run. :thumbsup:
Found a giant spider make a big *** web on the roll bar. So I left him alone as I was afraid of geting stuck in his web.
Sent from my SPH-L900
Installed my half doors today. Rattle can black for now, and I had to trim the panel to make them clear the cage. I love the look, but I really miss the armrest the full door provides when the window is down. I may make some tube doors and sell these. But, I'm going to enjoy them for now!
They look good Randy. When I have mine on, I just use the top edge as the armrest. But they do sell armrests for YJ doors.
Mine were black when I picked them up but I rattle can painted mine Olympic White. The closest I could find to the color of the fiberglass body of my Jeep. Darn close. Good enough.
Dain
I use a set of these door panels on my half doors. They have a built in arm rest.
Those are sexy. Link to where to a part number or manufacturer?
Okay you just cost me money :) Need to order those.
Wasnt Scrambler related and it wasnt today, but here comes the story anyways...
Have been wanting a decent TJ Unlimited for a while now. I found what looked like a clean low mileage (47000km or about 29000miles) rust free 2005 in Vancouver BC. So Monday, at 1130am est, I flew out to Vancouver with the intention of buying it and driving back. At 2pm pst, I get to the dealer that had it... It was low mileage, and rust free... however, it had obviously been partially repainted to cover up some kind of damage, had fender damage on both front fenders, and many DEEP gouges right to the metal in weird areas. It still had the original Goodyear GSAs from the factory that were VERY weather cracked... Decided not to take it because it wasnt worth the price. So back to the airport... Buy return flight at 6pm est... I got home at 730am est yesterday.
I could have bought another LJ while I was there but I couldnt get a hold of the seller and I didnt have time to stick around since I had to be home buy late Thursday, at the latest. Too bad. The search continues...
I was wondering about the PM, now I know, too bad it wasn't what you wanted:confused:
But, I have a nice one:rotfl::thumbsup:
I didn't realize that the 6 speed in my LJ was 1 to 1 in 5th until a couple weeks ago. For some reason 4th is always 1 to 1 in my brain. I'm not sure what I thought 6th was...double OD.
Nope, but a "double OD" sounds like a good name for a shot:rotfl::rotfl::thumbsup::cheers:
GM 6L90E transmission has a double overdrive-
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: -3.06
I'd like to use one of these in a project someday...
37" tires, 5.13 gears, 2000 RPM at 65 MPH. And, 83-1 low range with a 4-1 case...and being an auto that's more like 120-1.
What does that come in ??
Hydra-Matic 6L90 Transmission ( MYD ) 71706
Type: six speed RWD / AWD, electronically controlled automatic overdrive transmission with torque converter clutch. Clutch-to-clutch architecture, with integral Electro / Hydraulic Controls Module
Maximum engine power: 452 bhp ( 337 kW ), Diesel: 300bhp ( 223kW )
Maximum engine torque: 531 lb-ft ( 720 Nm ), Diesel: 520 lb-ft ( 705 Nm )
Maximum gearbox torque: 885 lb-ft ( 1200 Nm )
Gear ratios: MYD
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: -3.06
Maximum shift speed 6000 rpm
Maximum Validated Weights: ( Target ) GVW: 15000 lb ( 6803 kg ), GCVW: 21000 lb ( 9525 kg )
7-position quadrant: P, R, N, D, X, X, X ( X = available calibratable range position )
Case description: 3-piece ( Bell, main, extension )
Case material: die cast aluminum
Shift pattern: (2) Three-way on/off solenoids
Shift quality: Five variable bleed solenoid
Torque converter clutch: Variable Bleed Solenoid ECCC
Converter size: 300mm ( reference )
Fluid type: DEXRON© VI
Fluid capacity: w/ 300mm converter 300mm: 13.0L ( 10.8kg )
Transmission weight: w/ 300mm converter Wet: 109kg ( 240lb ) estimated
Pressure taps available: line pressure
Assembly Site: GMPT Ypsilanti, MI
Applications: Chevrolet Suburban
GMC Yukon XL
Chevrolet Silverado HD
GMC Sierra HD
Available Control Features: Multiple Shift Patterns ( Selectable or Adaptive )
Driver Shift Control ( Tap Up / Tap Down )
Enhanced Performance Algorithm Shifting ( PAS II )
Next Generation Tow / Haul Mode
Engine Torque Management On All Shifts
Altitude and Temperature Compensation
Adaptive Shift Time
Neutral Idle
Reverse Lockout
Automatic Grade Braking
Additional Features: Oil Life Monitor
OBDII / EOBD
Integral Electro/Hydraulic Controls Module ( Tehcm )
Control Interface Protocol - GMLAN
Supposedly HP and Torque ratings are figured at max load (15000 lbs).
