Rubicon Express 4.5" with 35" tires
jammer1
Maple Hts.
Oh
A question for you guys with the Rubicon Express 4.5" lift and 35" tires. How well do the 35" tires fit with the 4.5" lift. Did you need a body lift or Shackle lift for them to fit. How much do they hit when you bottom out the jeep. This jeep I'm building won't see much off road, mostly for good weather drives.
I rub my 33s with a 1" body lift, but I've seen others seem to end up with more lift than mine has settled to.
What year Scrambler (NT or WT) and is it stock axles?
It's a 82 with wt axles (stock). I have a cj7 with 33" and a diamond 3.5" lift and a 2" body lift, and shackles with about 1 1/2" lift. I just like the look of the 35" tires with the larger cj8 body. Would a 2" body lift help keep the body safe (normal road and light off road). I would put axle stops (extensions), I just want to make sure there's enough suspension travel that I'm not bouncing off the axle stops during reasonable driving.
I sit a couple of inches off of the stops I made. I can lay the stops on the axle tube on hard cornering if that helps any.
I have a 2 in body lift and 4 in springs and run 35s. My rocker panel is 26 off the ground. I cut the very bottom of rear wheel opening and nothing else. Lowere the rear bump stops by 4 inches and the front by 2inches. Front tires will rub on the frame in a tight turn with the tire pushed up but not bad.
The rear flares are Bushwacker YJ Pocket cutout Flares. The are large enough to go over the raised lip around the Scramblers rear wheel well. You have to drill new hole to install them though.
Couldn't agree more - the CJ8 body screams 35s. But the rear wheel openings scream 32s.
Love the proportions/scale...
But even with the R.E. 4.5, a 1" BL and M.O.R.E. shackles, I rub if I come off a speed hump too fast. If I did it again, I'd do less lift, 33s and trim some sheet metal.
This is the passenger side, rear - the tire is hitting the back side of the wheel opening.
I have the R.E. lift (still boxed on pallet). By any chance is the spring pack mount pin centered on the spring. If one side is longer could the longer side be put to the front (mines still boxed so I haven't checked, nor have I checked if it's already designed to mount that way). If not would Jims idea work and would it cause more axle wrap. It it does work, sounds like a good idea. Probably need a new drive shaft also.
Manhattan I love what you've done with the cj8. I enjoy watching the build and yours was the look that was pushing me toward the 35" tires. Thanks to all for the comments since I have to put the order in for the ring and pinion and need to make a final decision.
The center pin is centered in the spring. MORE makes a small plate that will allow you to move the axle 1". I tried them for a while and didn't like them, took them out. I used them in the front, it threw the caster out.
I might have explained wrong. Move the anchor bolt toward the rear (center the axle in the opening). If the spring came with the anchor pin not centered (between spring eyes) put the longer section in front of the axle (that's where the longer drive shaft would come in and was wondering if would increase axle wrap). If you drill a new hole for the anchor pin, I wonder if it would weaken the spring pack and if it could cause a crack between the holes. Edit, sorry Jim didn't realize Manhattan did post as I was posting. Like wise John, I have bad timing when adding a post. Thanks.
Longer anti wrap pads cut and shaped redrilled. I just did that on mine last week and it helped mine tremendously. I did have to re arc them though.
Don't drill holes in your leaf springs.
