- Fairfax
- VA
Black on black looks great! What's your plan with your roll cage? More specifically, will you have a roll cage that you can use with a half top and take on and off?
I've asked that they add gussets to the stock roll bar for strength and build the rest off that. I want to try to keep the classic lines as much as possible - or at least some reference to them. I have no need for the half cab, especially with the 2nd and 3rd row seating installed - the conversion back to half cab would be a major PITA.
It'll be tied into the frame (sandwich plates to avoid cutting the tub) using Genright tie-in brackets with the bushings for some give. The fabricator uses gussets on EVERY bend so that's great. He believes that using the gussets without the holes in them will tone-down the look a bit. Their welds are amazing.
IF IF IF we have to cut the dash pad - I'm pulling my cherry one and using a "lesser" cherry one from Jeeprdd.
Some pics of a sample/inspiration work from the fabricator below....we'll tweak it to match the Scrambler (looks, lines, functionality)....and it's going to be SWEET!!
Cheers,
Dylan
