Anyone moved their ignition control module?
Allan H
Bothell
WA
I just purchased and installed my third ignition control module in 10 months and was wondering what everyone else is doing to keep them from burning up?
Like many people, I've had problems with getting a reliable aftermarket ignition module. The first two I purchased were in the $35 range from quadratec. They worked fine when installed, but burned out and left me stranded with no warning! This last one (currently installed) came from NAPA, cost about $70 and has a 50K mile warranty. After doing some reading online, it seems like a lot of people have problems with the aftermarket modules, some have even suggested purchasing two and keeping a spare in the vehicle. Like many people, mine worked fine up until the day they burn up internally or just melt goo down the fender well.
I'm wondering if internal heat in the module is causing the problem, and if moving it to the front of the fender where it will get some air off the fan might be the ticket?
Thoughts? :wave:
Allan
[/URL][/IMG]
Mine stranded me in Colorado on the way to Moab. I would have bought a spare to carry if I could have found one, since we were headed way off the road into the canyons. $42 at O'Reillys. I see HEI on the next jeep trip...
Ask yourself WWBWD? The answer is HEI. Works great for me!
You can also upgrade to an MSD style module. Did that on a Waggy 360, worked great.
2, proofread and cleared by the NSA.
As others have said, ya just gotta get away from that system. Short of that, the best solution I've seen is mounting two of them side by side. When one fries, you just switch the plug over. Then get a new one and swap it with the dead one... and continue that cycle until you go HEI ;)
For those of us still running the original stuff, what's the process for swapping to HEI? Any ballpark idea what the cost is?
Check out the Overlander and other road trips threads for my ignition module issues that caused complete madness so many times that by the time I drove the jamboree back from the Colorado I was carrying extras in my suitcase. And sure enough, that one failed in Missouri ! I tie wrapped it to the top of the fender and its still there now.
HEI yes. X100. For my OEM jeeps, I carry a spare if on a long trip.
Instead of "Made in China" parts store replacements, go pull these things out of Fords in junkyards. On my green Scrambler, the factory module lasted 124,000 miles/30 years:twocents:
But, I also carry a spare:twocents::rotfl:
There are probably literally thousands of how-tos on this out there, with a number on here as well in different threads. You can buy a ready-to-go setup or make your own and that's going to affect the cost. Search on here and Google are going to be your best friends to check into it.
I can see the money rolling in from tshirts and stickers!! #WWBWD?
If you look for these at a junkyard, be careful of the year. I know Ford had a class action suit against them that they settled in the early 80's. I had a new 78 Mustang, I knew about those crappy modules all too well.
Heat is their enemy. I had them leave me stranded, and I'd pour cold water over them- they'd start working again a minute later...but not for long...
