7th:
Finish up the underside of the tub do touch up
Finish back of tailgate
paint doors
Fix body mount
Buy bolts for body mounts
Finish the brake lines
8th:
fix leaf springs
castle nuts
drop pitman arm
Mount exhaust
Fix gas lines
Mount gas tank
9th:
mount the tub
tailights
gas tank hoses
tailgate
10th:
brake boost
bleed brakes
Heater
Steering column
Steering bracket assembly
Buy new wheel
11th:
Dash electrical
Prep hardtop
Paint windshield hinges
Deal with cross member
12th:
windshield and wipers
electrical
wheels
Paint hardtop
13th:
electrical
glass hardtop
starter motor
14th:
Heater
headlights
grill
Radiator
15th:
fluids
Differentials
Transmissions
brakes
Oil
Radiator
Seatbelt harness
Paint roll bar
Clutch linkages
peddles
You need to have someone pump the pedal while you open the blender screw. Unless you have a really high end bleeder system it's the only way to get the air out.
after finally getting the the brakes all figured out, i went to the junk yard were i found a 3 point harness for a scrambler... turns out i just bought the whole scrambler....
The white scrambler was all together........ Then i took it to the farm and blowup the universal joint between the driveshaft and the differential......
So do you consider it a success since you got it all done within the 100 days before breaking it? I would count that as a win. But sorry you did not get to take it with you to school.
I think getting a 2nd Scrambler is a win, but I have to say the explanation left me wondering how come?
U-joints are easy to replace, hopefully that is your only issue and it isn't something else.
Congrats on getting your Scrambler 'done' and look forward to seeing you get the U-joints repaired so you can fully enjoy it at college.
Would you be able to send me some pics of it? Specifically of the exterior, the interior and the engine compartment?
I think I owned this Scrambler years ago, and it'd be awesome to confirm if it is the same one that I sold back in '98 or '99 in Pennsylvania. It has a few distinct characteristics that lead me to believe it is the same one.
A scrambler up in the air like that on an oversized forklift is just about the coolest pic I have seen in a while. Congrats on getting the white one to where it is, and the new purchase too!
