Started the wiring harness job yesterday. Got the old ECM off the firewall and discovered my 81 is really an 82 when the lost VIN plate fell out from behind it. Oh, well, don't have to argue with the insurance co any more. Drove the OTHER 82 out to the same rock I parked the LJ on yesterday to check for rubbing on it. A little on the forward edge of the rear flare. Need more spring height, I reckon. And a pic of the LJ for comparision:
Dumb question. This is the second time in probably twenty or so reply's that when I put the attachments in the tread that they came out as a attachment you have to click, not as the attachment open. What am I missing the two times they didn't open. Thanks.
Read through it about 3 times now, I'm going a little different by using the AX15 bell housing in order to run a hydraulic clutch. But a ton of useful information I've been poring over your thread for all the actual install tidbits.
