firefighter736's Build Thread
mhinchliffe reminded me that I hadn't updated my thread in a while.
I practiced removing spot welds on the corner that I am replacing. I learned that drilling a pilot helps quite a bit.
I've almost got all of the holes (from the top snaps) in the side filled. Not perfect, but a tiny bit of filler or high build primer should take care of it.
I didn't have a 20amp breaker for my welder setup at the shop yet so I had my buddy weld up a couple of engine stands to make a rotisserie.
Started working on cutting the rust out by the Cowl Supports. Started with the passenger side and found that there was a little bit of floor rust but the cowl support was in really good shape. I'll sawzall the welds and cut out the floor section and replace the side and this side will be good.
The drivers side was not as nice. There are several spots in the floor and the cowl support is all but gone. I don't quite know what I'll do about replacing the cowl support. ClassicEnt has the whole piece but I'm not sure I want to give them the other half of the paycheck that they got for the Floor and tailgate end support :crazy:
All that's left of the driver cowl support brace :huh:
That's all for now. Hopefully will have the Jeep on a rotisserie next week which will make cutting those floor sections out a little easier.
New shoes came in except....one was missing. I look back through the shipping numbers and one randomly got returned to sender at the shipping depot in Richmond :angry: Called 4WD and as soon as it gets back to their warehouse it will be shipped back to me.
Check that rear bed floor piece. Mine came from Classic with the underside support that the body mounts rest on welded in the wrong place. I didn't catch it until after I put the freshly painted body back on the frame:twocents::twocents:
Thanks! I think I would have murdered someone if I got it all the way ready to put on the frame and found that.
When I cut my bed out I'll lay the two side by side to verify.
What size tires?
32x11.50x15. Was a little scared to go 33" with only a 2.5" lift. I saw JeeperDD's 8 on 32s and loved it so I hope they look that good on mine.
I'm going up to the shop tomorrow morning to work. I'm going to try my hand at making the cowl support brace. If I booger it up or get frustrated I'll shoot you an email and take you up on your offer. Thanks again!
I could have picked up that 4th one for you up here, but don't have plans to head down your way.
The A pillars arnt too bad to build. I did mine in two pieces to make all the angles easier to line up . They were easier than the B pillars for sure. There are some pictures on my Oscar cj7 thread that may help.
Lemme know, got plenty of 16 ga, a shear and finger brake ready to roll. I looked at IaAFF build and he did great making it in 2 pcs. Whatever you need just give a shout.
Thanks for the offer, but it was already on the way back to Florida before I even knew the other 3 were at my door. Hoping when I get done I'll be able to come to a VA get together and meet some of you guys.
Awesome. Great pics in that thread. Thanks!
In the interest of time and sanity I'll probably take you up on this. I'll shoot you a PM later today.
Has anybody else had bad luck with 4WD.com? I've had 3 not so great experiences in the last month or two so I'm wondering if it's a trend.
1) I am very particular about what I order. I have a spreadsheet of all of the part numbers I have purchased for the Scram, and all of the part numbers I'd like to purchase. On two occasions I have called and ordered a part with the specific part number and on those two occasions I received something else. In the first case, I received shackles that were Rubicon Express when I specifically ordered M.O.R.E and when I called they said that they couldn't get the ones that I wanted (even though they were on the site)...so why did they send a random set instead of telling me that? In the second I ordered a non-radio dash overlay and received a radio one.
2) The most recent situation is that I ordered a set of 32x11.50 BFG ATs. 3 showed up, one was returned to sender due to a shipping number error or soemthing else. I call them, they say they will ship out the tire once it gets to the warehouse. A week and a half later a 31x10.50 shows up at my door. Now I have to drag this thing to a UPS store and ship it back so that I can (hopefully) get the right sized tire.
I'm glad I'm not in a rush at the moment.
Super frustrating.
I've had problems with them (even have one of their stores 25 min. away) I'm done dealing with them (I even have a gift card from Christmas a year ago that I have yet to use). I can usually go on amazon and beat their prices, even going direct to some manufactures I can beat their price. It's funny, if they didn't screw me over about 4 yrs ago between tires for my three work trucks and the cj7 extras plus the cj8 build I wouldn't be surprise if they lost 14 grand.
The weather has put me behind a bit but here is an update:
I cut out the drivers side outer floor and what was left of the support. You can see the outer floor support that I made in this pic, as well.
I finally made it back to the shop today (60 degrees today! Snow tomorrow!) and finished welding in the outer floor piece. Please excuse my poor welding skills... this is the first big piece I've ever stitched
mhinchliffe was nice enough to take the dimensions of my cowl brace and bend me a really nice piece. After I got the floor tacked in I test fit my body skin piece as well as the brace. Between the floor piece, the brace, and the body patch it's not perfect but I'm super, super happy with how it's turned out.
That A pillar looks awesome.
Yes, it does. mhincliffe is the man.
Made a push and finally got the rotisserie done and started working on knocking the rust off the bottom of the tub. Made the rotisserie about 3 inches too short and can't get it all the way around but that works fine for what I'm doing.
Looking good man. Shouldnt be hard to make it a little taller or you could add some jacks in the uprights and make it adjustable.
Took advantage of a long weekend and was able to do quite a bit of welding.
First, I fixed the rust under the pass window hinge
