boxes of parts to become an '82 scrambler
Skeltor
Flagstaff
Az
I purchased a 1982 scrambler from a friend a few months ago. It was running years ago. He decided to take it all apart to clean it up and repaint. He moved a few months ago and wanted to sell it so we bought it. It was completely taken apart. I have never seen it put together. The seller helped clean and paint the frame, mount the engine and transmission, and add the other necessary parts to get it to a rolling chassis.
A few specs:
'82 scrambler
1991 chevy 350 TPI engine
700R4 automatic transmission
corporate 20 rear axle single piece
dana 30 front axle
I am a novice. I am just learning as I go and need all the help I can get. I'm posting here in hopes of some input along the way. I have a lot to learn.
Since having the jeep I have put in new fuel and return lines, new shocks, steering stabilizer, added brackets for two rows of seats in the back, and a few other things.
The body was recently painted and with the help from a few guys it was placed on the frame yesterday. It doesn't seem quite right. The rear shackle is longer than the front shackle and also there is a 1" body lift. Does anybody have any input?
I'll post a few pictures in a moment. I'm having a hard time uploading them.
[/URL][/IMG]
It seems really tall to me. I think changing the rear shackle to the same length at the front shackle would be a good idea. Other than that, maybe that's just how tall it's supposed to be. The tires are 33s.
Welcome! You've got a good start there.
As far as the shackles...they're easy to change. Just leave them alone for now and continue the build. Once you have the full build and weight on the suspension, then adjust the lift and shackles as needed. It may even take some time and flexing to get the springs to settle.
Thanks for the input, John. to change the shackles I have to drop the gas tank which seems like a bit of a pain. I guess it's all part of the process. Tonight I was thinking to wait on the shackles too so your opinion helps.
looks like you have a great start to a great Scrambler.
If those are new springs you may want to drive it for a bit before you decide. The new springs on mine settled 2 to 3 inch's in the first 500 miles.
Congrats, looks like it will be very nice.
To answer your question, I believe you need to be a paid member to delete a post. It's well worth it :)
Welcome and :cheers: for taking on this project as a novice, diving in and making it happen! I love it :thumbsup: You'll know every nut and bolt on that Jeep when you're done and won't be able to call yourself a novice any more ;)
Agreed with the others, don't worry about the height or shackles yet. Get it together and running and see what happens.
Don't worry about the lift. With that kit it can take some time for the suspension to settle. Looks like it's coming along nice.
Welcome! :thumbsup:
What brand wiring harness? I see I am a day behind, hopefully you were able to get it in yesterday. I find it is best for me to be alone with no interruptions when installing new wiring. As mom always said, " The only way to eat an ellephant is one bite at a time".
Have fun! :wave:
I got a painless wiring harness #10106. I didn't do a lot. I laid it out and laid out the old rats nest and tried to figure out where all the gauges go. The kit came with connectors. How do I connect to a gauge back light? They don't unplug. Splice to the existing wire?
Most use original light sockets with new bulbs spliced/soldered to new harness. I have seen a few use the new LED lights that look great, but I personally haven't tried them. :wave:
twist and turn and they will pop out
Thanks guys for your feedback. I thought I was ready for wiring, but I have been spending a lot if time trying to figure out where things go.
