- Redmond
- OR
Commando's are really cool. Depending on the year, there are big and small differences. 72/73 are called Bullnose Commando's. They look sorta like Scouts. You get an I6, or a 304. Also saginaw style steering and usually disc brakes. The best mechanicals of the bunch, if you like the look. If you don't like the Bullnose look, a CJ front end is almost a bolt on swap. 66-70 are the earlier series, usually found with the torquey 225 V6. Steering is a bellcrank system, and not as desirable. Late 70-71 retain the classic look, but have the better saginaw steering, and the 225V6. Mileage is not great, the auto trans is a TH400. Replacement parts can be somewhat difficult, although enthusiast driven manufacturers are more common now than when I had mine. One plus or minus, depending on your height- the Commando gets it's sleeker looks because the tub floor seems to be about 5" higher than a CJ's. Imagine the floor starting at the top of the CJ door sill. So you lose 5" of headroom, and it's really noticeable in the back seat if your kids are tall. But, this makes it really easy to get into, even with a small lift, and it's also easier to clean as everything can be hosed right out! Seems like lots of room behind the back seat, even with the sloped tailgate. Beware of rust in the rockers, and in the tailgate. If you get a hardtop, it will be all metal- sliding windows are a bonus. The windshield is essentially fixed, no folding down, at least not stock. A V8 swap is really difficult on the 66-71's, they have a shorter nose.
I'd love to get another 70/71, but I still have Scramblers to finish.+
As far as mileage estimates on a Scrambler, here's another option. I have a 5.3 LS style engine, 4L60E auto, 4.56 gears and 35" tires. With the cage and extra goodies, I'm at about 4500LBS empty. I can get 18MPG highway if I keep my foot out of it, cruise at about 60. But...I have enough power to keep up with a newer Mustang GT...and pass motorhomes on grades effortlessly. (That's when the gas mileage drops to 10ish...)
Darn it. After seeing this, I looked at some pictures of my 70...I miss it. Someday I will have another.
