First post with questions???
Commando's are really cool. Depending on the year, there are big and small differences. 72/73 are called Bullnose Commando's. They look sorta like Scouts. You get an I6, or a 304. Also saginaw style steering and usually disc brakes. The best mechanicals of the bunch, if you like the look. If you don't like the Bullnose look, a CJ front end is almost a bolt on swap. 66-70 are the earlier series, usually found with the torquey 225 V6. Steering is a bellcrank system, and not as desirable. Late 70-71 retain the classic look, but have the better saginaw steering, and the 225V6. Mileage is not great, the auto trans is a TH400. Replacement parts can be somewhat difficult, although enthusiast driven manufacturers are more common now than when I had mine. One plus or minus, depending on your height- the Commando gets it's sleeker looks because the tub floor seems to be about 5" higher than a CJ's. Imagine the floor starting at the top of the CJ door sill. So you lose 5" of headroom, and it's really noticeable in the back seat if your kids are tall. But, this makes it really easy to get into, even with a small lift, and it's also easier to clean as everything can be hosed right out! Seems like lots of room behind the back seat, even with the sloped tailgate. Beware of rust in the rockers, and in the tailgate. If you get a hardtop, it will be all metal- sliding windows are a bonus. The windshield is essentially fixed, no folding down, at least not stock. A V8 swap is really difficult on the 66-71's, they have a shorter nose.
I'd love to get another 70/71, but I still have Scramblers to finish.+
As far as mileage estimates on a Scrambler, here's another option. I have a 5.3 LS style engine, 4L60E auto, 4.56 gears and 35" tires. With the cage and extra goodies, I'm at about 4500LBS empty. I can get 18MPG highway if I keep my foot out of it, cruise at about 60. But...I have enough power to keep up with a newer Mustang GT...and pass motorhomes on grades effortlessly. (That's when the gas mileage drops to 10ish...)
Darn it. After seeing this, I looked at some pictures of my 70...I miss it. Someday I will have another.
Is nearly due for one. There is one for sale here for 12k right now.
Edit: I actually wrote "I'd nearly kill for one"
Randyzzz, Thanks for the info! They seen to hold together pretty good! Found several with a 3speed trans (floor mounted)! What/any 4 or 5 speeds fit with minor/minimal change? What is the third gear ratio or what is the 3speed trans ID so I can find it!
Are you talking about Commandos? The transfer case is a D20, so your options for a 4 or 5 speed would be the same as a CJ from those years. You can adapt a truck type 4speed or even an AX15 5 speed to the engine and Trans with adapters from Advance or Novak. If you went the 5speed route, a D300 transfer case instead of an adapter to the D20 might make sense.
The stock V6 3 speed should be a T14 or T86 for the V6. The 72-73 will have a T14 or T15 on the straight 6. The 72-73 is a great platform to swap in a Cherokee 4.0 and Trans adapted to a D300.
Great info!!!! Sounds like I don't have to reinvent the wheel! Doable with available stuff!
You guys and this site are Great:woohoo:!!!!:bacon:
IF I every get mine running and Randy stops making jokes about me I'll be glad to see what the fuel mileage is like with the 5.3 vortec/4l60e with 2.73 gears. I'm not sure how the gears are going to work out but I'm going to give them a try.
Who, Me? :woohoo:
Welcome! Everything you want to do is possible and you have some good examples from folks who've posted here, but just so long as you're looking to spend some money on a nice one or do a good bit of work on a build. Either a Scrambler or a Commando.
Sounds like you are thinking right, but I always get worried when I see these types of questions from someone new on the forum when I think they may get the impression you could buy a $2k project and find a good 4.0L and tranny and have a reliable 1000-mile road tripping Scrambler in a couple weeks of work. Plan to go through EVERYTHING and if you find good, usable parts, consider it a bonus. If you're looking to drop more $$$ up front, then you can be closer to what you need out of the gate.
Not trying to be a wet blanket, just want to do a reality check. :thumbsup:
Somewhat unrelated, I almost fell out of my chair when I saw that you got ol' Mike out of the woodwork:
That's probably the hard part lol.
I can't help you with that. I bought my CJ8 in my 20's (currently in my 50's) & 2 wives ago :D
What I can tell you is that whatever issues you may have, the fine folks on this site can help you work out!
Welcome & congrats!
WOW, talk about a blast from the past!!! Hope you're back to stay a while old friend. :cheers:
I know that it will not be a turn key operation,(don't have that kind of money) so that means work! My daily drivers have been a 68 f100 then a 66 250(still have it)! Also had a 69 crew cab, step side dodge in there(family car):D! None were show cars but the 68 and the dodge went cross country several times each! That has been since the 80's so they are not short term trucks! Knowing the mechanicals and able to get the parts is all that matters!
