I completed a little bit more emissions system restoration work this weekend.
I plan on "reactivating" the EGR system on this Scrambler. I installed a new EGR valve a few years back, but never hooked it up, because the "cross over" pipe (metal tube that connects the exhaust to intake manifold) was not installed correctly.
This metal pipe is what allows the exhaust gas to travel into the intake manifold when the EGR opens up. On my Scrambler, it was threaded into the exhaust manifold fine, but it was just kind of jammed up into the intake. If the EGR would have opened up, the way it was, the intake would have mainly just been sucking in outside air, not exhaust.
Quick picture showing where this pipe goes, bottom of intake, above the O2 sensor, outboard of the intake manifold heater:
Amazingly, with just a little bit of PB Blaster, I was able to remove the fitting from the exhaust manifold. I ordered a new pipe, thinking that my old pipe's fittings might be damaged, but they were not. Quick picture showing the old and new pipes:
The old pipe is steel, with steel fittings. The new pipe is steel, with brass fittings. I sourced the new pipe from Colins Brothers, but I believe it is available at other locations. Mine was in a Mopar parts bag.
My exhaust manifold threads were fine, but my intake had slightly boogered threads. I pulled the O2 sensor/throttle bracket out of the way, and tried to run a tap into the threads with the manifold in place. I could not re-tap it with the manifold in place. BUT, I was able to run a steel plug into the manifold, back and forth slowly like you would with a tap, and was able to repair the threads. After running the plug through the threads, I re-threaded the old fitting into place by hand, so mission accomplished. I did not want to pull the intake, that is a PIA.
So, after repairing the threads, I tried to install the new pipe as it came, with the intake/exhaust manifolds installed on the engine. The pipe would not line up right with the manifolds installed. I would "assume" it is best to install this pipe with the manifolds off the engine. I did not feel like going through all that, so I slightly "tweaked" the pipe to make it line up. This replacement pipe is pretty thick, so you can't just tweak with your bare hands. I inserted a breaker bar in one end, a long socket extension in the other end, and was able to slightly "tweak" it. After "tweaking" the pipe, it slid right in.
As you can see, the pipe is a unique shape. Even after "tweaking" the pipe, I put copper anti-seize on the fittings threads, and tightened them up very carefully. Since the intake manifold is aluminum, and you have to use a 1" wrench to tighten up the fittings, work slowly and carefully. It would be very easy to cross-thread/damage the fittings or manifolds threads. Total time to remove/install the new pipe, with the manifolds in place, 3.5 hours
With the new pipe installed, I need to check my EGR CTO switch and air cleaner mounted thermal switch, before hooking up the EGR. My EGR CTO switch is a simple two port affair. It should not allow ported vacuum to flow until the engine coolant has warmed up some. It will be easy to check this with a vacuum gauge while the engine is warming up. As for the air cleaner mounted thermal switch, since the temperature here is already staying above 60 degrees, I will have to wait until next winter to see if it functions correctly.
One last picture, showing how I ran the vacuum lines for the two air cleaner trap doors. I talked to JeeperDD and JeepAddict, this is how these lines were ran on their original Jeeps:
Of interest is the TAC trap door hose/check valve routing. I could not find much information on this.
The check valve mounts with the black end toward the vacuum source (it even says vacuum on the black end).
The check valve mounts between the Thermal Vacuum Switch and the "T" from the vacuum source.
Vacuum source goes to Thermal Vacuum Switch tube with small hole.
Vacuum flows to TAC motor from Thermal Vacuum Switch tube with large hole.
Even with the check valve installed, my TAC door is staying on the "Heat On" position. I am "thinking" my thermal vacuum switch is bad. I have a new one on the way.
I installed my new SolVac, and it functions as it should. Upon a hot restart, the vacuum portion is holding the idle high for 15 seconds, the vacuum releases, the electric portion hold the idle slightly higher for 45 seconds. I need to hook up a tachometer and adjust the speeds some, but other then that, it is functional.
That's it for now
