TJScrambler - Getting Started
Getting stuff fit. Trimming needed around the t18 tranny
Not much to report. Cold sick from the kids. Got a bit of time to test and realize the frame mounts are off I think. By a lot
Metal fixing. Off and on
I am going to have to trim a bit more, but it is getting there.
My main issue is the Matkins frame body mounts seem to be quite a bit off.
Trying to find the frame dimensions to compare to see... might need to relocate a few of them.
So, in talking with Brooklyn and getting measurements of his frame/tub and mine, we are close on the frame dimensions and they are close to what stock is... the new replacement floor I have is pretty much the issue. The forward to mounts are really what is causing the issues. I think I can fudge the rear 2 of the floor section to get it to work, but the front is way off... like 1.5" or so.
The rear most is also off from stock, but at this point, I need to mate what I have together, and the matkins vs. the classic enterprise replacement is only 1/4" off or so... the newly constructed tub vs. the original dimentions would be off by almost an inch at the rear most mounts.
Bottom line... anyone buys this and wants to put a stock body on it, it ain't gonna happen without work.
Me putting this together is going to take some doing, but shouldn't be horrible, more than likely i have to move the front 2 mounts up a bit.
Deep into the teardown of this 80 cj7. No need for unbolting body mounts with those frame ears. Scary
OK, it is going to come off like a lot of complaining, but I couldn't be happier (outside the colds) to get done all the other stuff.
I haven't worked on this in some time, that it true.
1) I had 6 cord of wood delivered in a grapple load.
- It was cut to length and transported over to the wood area... then I started to split and stack it, I am about 1/3 done with that process.
2) I have bought 3 project/broken vehicles that I have stripped down and kept some parts for the build, but sold off other stuff on CL and to members to make extra $$$$.
- This has taken a lot longer to do and I didn't have a ton of room to do this with it being winter time, but I have done 90% of this.
- The valve body in the CTD 2500 Ram cracked and I needed a ton of transmission work done. I also had a ball joint recall and needed new front u-joints, so that was VERY unexpected and VERY costly.
- Kids camp payments are due for the summer... those of you that have had to do this, this is a first for me, caught me off guard actually, never knew you had to pay UP FRONT for 10-12 weeks of summer camp. Weekly payemnts are bad enough, but all up front combined with the transmission was quite an eye opener.
3) We got sick... BADLY... kids brought 3 different sicknesses home... first was a head cold, then a nasty stomach bug, then what I can only describe as the flu... and now allergy season with the warming temperatures.
- Everyone has been there, but I had to take a lot of time off to care for the kids, which required me to work a lot more at night/weekends when I normally do this stuff.
4) 2 kid school vacations... one we went on holiday, the other we didn't, either way, not a lot of Jeep time when the kids are around or we weren't.
5) Big Jeep trip planned coming up in a few weeks I am preparing for as well.
- More on this later.
All in all, I have no complaints, even though there is a lot I could.
My wood is mostly ready for next winter, I have another 8-10 hours and that will be done.
All of the Jeeps have been disassembled and all those CL ads are written, etc. and parts are slowly selling.
It is also seasonal.
In the winter time I get a lot of time on the weekends to do this work.
Spring is the toughest, getting the yards/machines ready to roll.
The tractor popped a hose as well, which needed a new one, so while I was in there doing that, I drained the fluid, new filters, and replaced 2 PTO output seals to have it be less "Jeep Like" in marking its territory all over.
The goal is June 1st getting back on it.
The workshop should be rid of all parts/pieces from the Jeeps I have collected that I have to deliver.
I will be picking up more parts along the way, but it should be far less than what I have scattered all over.
A quick clean up and getting the Jeeps out to drive this summer and I should be back in business.
Thanks for saying I inspire you... I hope in a month to be back to doing so!
Family comes first CB, Jeep second.
Now the pile of wood that's your own making, cant you just buy it in pre-cut form what i would call "logs"?? :wave:
Wow when it rains it pours. Tell me about summer camp. Do your kids (all American kids?) go off for 10-12 weeks each summer? That's a long time. I couldn't imagine being without my little rat bags for that long.
