I was able to get a bit more complete.
I installed a new PS pressure line, new rubber return line, installed the alternator/PS pump, belts, fan with clutch:
I used a NAPA PS pressure hose. It is "almost" an exact fit. I had to carefully tweak it to get it to fit, but no big deal. Everything else just bolted together.
Bolted on the fenders, all the braces, and the battery tray:
Hesco does not supply a new vapor canister with their kits anymore, or for the last few years. They are about impossible to find new. So, I bought a used 1995 YJ vapor canister off of eBay, this is the same thing that used to come with the kit.
I also installed the grill, radiator, and fan shroud:
I might need to see if I can find a new fan shroud, my original is cracked in half, and the fan has chewed it up a bit. My standard rotation seven bladed fan also has a chunk missing off one of the blades, so I might/should replace it, too.
Installed a bunch of other easy stuff, too:
spark plug wires
solenoid
wired up alternator
installed jack/jack plate
temp sender
oil pressure sender
I will probably install my new vapor line next, plus work on some of the wiring.
As for the fuel line, I am thinking of doing the following, since I bought a new pre-bent fuel supply line:
Run the line like a stock CJ on the passenger side. Then, make a new line to cross under the engine, then back up to the intake manifold. My regulator is at the filter, which is at the rear of the Jeep, so I only need to run the long supply line. If I run the line this way, it will keep it on the opposite frame rail from the exhaust.
Or, I can make the pre-bent fuel line work on the driver side frame rail. I did this on my Red Scrambler. The only "problem", it will be on the same side as the exhaust. But, it will hook up easier to the Hesco supplied fuel line that bolts on to the intake manifold.
As for fuel pumps, well, I have an interesting "plan", just have to execute
