IAFFCJ 81 Scrambler
And this happened today also so may be a little harder to get as much time in the garage for a while. Lots of energy and very curious.
Awesome! Puppies are so much fun, but a ton of work, too!
We brought home a Shepard mix pup from a local rescue event. This was about a month ago. She's extremely intelligent and a tazmanian devil too...
Thanks everyone. She is defiantly a cute bugger. And has totally flipped the status quo of the house upside down.
I did get a chance to get a few minutes to work on the scrambler today. All the parts came in to finish up the brake lines to the calipers. Came out very well I a a little concerned with the length I chose but with this set up it is very easy to change them out for longer if necessary. I am going to let it ride until I can stretch the suspension out again. and that is going to take a running machine i'm tired of pushing this in and out of the garage.
I also installed a few small trip pieces in between puppy naps this afternoon. Some parts have also been arriving daily I am actually very surprised how fast things are coming in with it being Christmas time. All new cables from MTS arrived and are freaking awesome, also a new blazer motor arrived today as well. The heater core should be the last thing that I need to get the heater box rebuilt and installed and it is scheduled to arrive on the 28th. This should give me enough time to enlarge the hole in the firewall to get everything ready to go.
Shifter I have been waiting for came in the other day. With no heat in the garage I haven't had a chance to really work out how it it going to go in the center console but I am pretty sure I am going to be able to make this work the way I want. It may very well take some cutting bending and welding of this brand new cable shifter kit for the Atlas but it will all be right within reach with no leaning out of my seat to take the front axle out or shift gears.
Looking great I've used the same style shifter in Blue for decades. Love them :thumbsup:
With the cold snap that has hit most of the country right now we are in the same boat as most with single digit temperatures for the last few weeks. It has been difficult to get anything done in my non heated shop. (WE cant all have nice work spaces like JeeperDD). So to keep things going I finaly cleaned off my work bench in the basement that has been collecting stuff for quite a while. Spent the day in warmth rebuilding the heater box for the scrambler.
New Blazer motor upgrade
fresh coat of paint
new weather strips to flaps
new heater core
YJ style vent ducts for the floor vents.
full set of 5 new cables from MTS Company- These are awesome a huge upgrade over original very well built will defiantly use them again.
Now to enlarge the hole in the firewall and install.
fresh coat of paint
new heater core
Great job... I hear you on the cold... heading out now... it got to 10 today but I have to get some things done out there.
Do you have a link to the cables? I definitely want to check them out and order a couple of sets.
http://www.mtscompany.com/airbox.htm Here is the link to the cables company. Their web page leaves something to be desired but if you call on the phone they are very knowledgeable and friendly it took me longer to find my credit card then for them to make the order.
Just an FYI i would not call these economy priced however after I got them I think they are worth every penny and made in the USA is also a plus for me.
Looks awesome. Making me feel like a slacker. And I have not even been motivated to clean out my spot in the garage so I can even FIND the tf999 I need to work on.
Had a heat wave today temperatures were just above freezing so I spent a few hours in the garage cutting the firewall for the Blazer blower motor and mounting the heater box.
Made a template out of steel as I have heard horror stories of folks trying to use wood and having the hole saw walk around on them. This produced a very clean cut however the hole saw was just a bit too small the motor fit but had zero play and I couldn't get any of the mounting bolts through the firewall. After a little work with a die grinder everything is installed. Need to install the windshield washer squirter and the defrost ducting and we should be good to go once the cables are all attached.
I guess i need to get my butt back up there to help you do some more wiring. :thumbsup:
Cutting the firewall is the least fun part of that process. Well worth it for the amount of air that motor moves.
Did you put anything on the vent hole towards the bottom of the motor? I didn't, but seeing this reminded me that maybe i should.
Motor came with a plug. I felt that leaving it open was most likely not the best plan to I put the plug in it. Not sure it is the right answer but we will see.
Yes please if only i could find a day to get the paint fixed on the dash that could all get wired up also. Not looking like painting weather for a while.
So JeeperDD is planning on coming up on Tuesday to give me a hand and see how much more wiring we can get done. In an attempt to be as ready as I could i knocked out some things that should speed up the wiring and let it be done and not have to be redone.
Battery mounted with two buses one for power and one for grounds to help keep the wiring as clean as possible.
Also got the windshield washer squirter cleaned up and mounted. Not sure i will ever use it but its there is I want to.
Heater system is SOOO close to being done. Defrost installed. Missing one bracket but my Dealer has one I think. :D
Engine also got a little tummy tuck today. F Body pan installed so I could put the starter on we should be good to go now.
With the Truck pan
With the F Body pan
Its on there I promise.
Then one final test fit before we called it a day. Looks like they should fit just fine.
Well tried to get the paint fixed on the dash yesterday with the temperature being in the mid 60s. Guess I wasn’t patient enough and put too many coats on with too little flash time. Had a short amount of time before the cold medicine I had taken put me to sleep. Well should have been slower it looked awesome when I went in the house but has 4 huge sags in it now that it dried. Guess I’ll get the console finished up and try for paint again in the spring.
After 6 days lying around with the flu finally got some time in the garage today. Decided to work to get the console finished up as it seems to be the key stone to a down hill slide to completion. SO today I got the shifter mounted in the console and the first piece of the coverings made up. Next is to get the transfer case shifters figured out they will need some modifications to get the set up and fitment that I am looking for.
Starting to try and figure out how to fit all the shifters.
Installed the neutral safety and reverse lights switches in my Art Car shifter. Super easy once I figured it out way less needed to come apart than I had apart :shrug:
Finally mounting structure welded in and first part of the skin mocked up.
