I was busy yesterday. Got some new toys for brake lines. front driveshaft was a little to close to the crossmember, so I notched that. Welded on ford shock towers, and burned in the motor mounts. I also got the gas tank pulled out and cleaned.
Worked on fuel lines and transmission lines.
It was a pretty productive day, and then it went totally sideways
. Picked up a running driving 82 cj7. Needs a couple little things. Figure I can get those worked out and then wheel it in a couple weeks at Oakridge. After that it will probably find a new home.
