A Scrambler fell into my lap
Finally got my Scrambler transported down to Georgia. It was a nightmare. Was supposed to be here five weeks ago.
Its in really good shape, just needs a very, very deep cleaning. Then I can start figuring out what I need to do to get it running again. Need to find a few original parts that were replaced. It also has three gun racks in it.
Kinda sad the AMC20 has an A code. 3.54 gears with a four cylinder doesn‘t seem like a great combo. That can be fixed later though.
Could be worse - you could have 2.73s!
Very nic. :thumbsup:
Let the fun begin. :wave:
Is there a good place to find a build date on a CJ-8? Or do I need to decode the drivetrain components and make a half educated guess?
There is a decal/label on the driver's side, inside below the door sill with the month/year of manufacture.
It may no longer be legible or even still there.
Good luck.
I’ve had a little time to clean this out. There have been 30 lbs of mouse turds in there. The carpet was a lost cause so I threw it out. The radio and oil pressure gauge have been replaced with aftermarket units.
What I think was the tag with the build date is pretty much faded to oblivion.
The floors will need a little patching but overall its in great shape.
I also found some grease pencil marks on the core support.
Also anyone seen this storage shelf thing before? It was bolted the bulkhead behind the seats
I have something just like that They are usually used behind the seat of a standard cab pickup. Its probably made by Dee Zee.
Since that thing isn't Jeep specific its going in the trash. Its pretty gross. On a brighter note I got the seats cleaned up and I think they came out pretty nice. One's pretty torn though.
Finally got some time to do scrambler things again. Pulled the radiator, starter, and carb today. Found a carter YFA from am ‘81 Ford F-150. Going to see if it works since it has no stepper motor and doesn’t need a computer since mine is MiA
