- Biloxi
- MS
Might high center on the top of test hill.....might....
Depends on how fast you are going
Obviously you can't accommodate everyone perfectly. I suspect BW that you are in the 95+ percentile.
I also noticed how high you sit in these. I'm 6-6'1. I didn't try adjusting the seat down. When these cockpits are layed out they should be designed to accommodate the vast majority of the population size. They have 3D manikins in various percentages of the population. It's a delicate balance to fit as wide a group of people as possible. Obviously you can't accommodate everyone perfectly. I suspect BW that you are in the 95+ percentile.
They should have more adjustment in the seat and mirrors. Hopefully if enough people 'complain' Jeep will do something to fix.
That’s all true but this is the first Jeep I’ve not been able to get in since the older/smaller CJs. DD an LJ with no issues and had a JKU for years that I always drove fine.
So my point is that Jeep has reduced the group for which they are designing. That’s the screwup IMO
I hear ya. It would be interesting to do some investigating into why the JL seats/cockpit are so different from the JK.That’s all true but this is the first Jeep I’ve not been able to get in since the older/smaller CJs. DD an LJ with no issues and had a JKU for years that I always drove fine.
Or, they just created the potential for someone to tap into a huge aftermarket accessory item.So my point is that Jeep has reduced the group for which they are designing. That’s the screwup IMO
Or if you’re running paddle tires...?Depends on how fast you are going![]()
I agree with designerrob and BobWalton. I will try it but I am almost 6'6" and I would have been a potential buyer. Bummer.Would you be a potential buyer if you did fit?
Or, they just created the potential for someone to tap into a huge aftermarket accessory item.![]()
I had 2 jeep Liberty's one with leather interior and one with cloth. The one with the leather interior sat much higher due to a number of things. The seats themselves were completely different and the leather seats had more padding plus the heater. The other major difference was that the leather interior were power seats so with all the electronics in the rails it took up more space and were adjustable in height as well as position. even with the power seats at the lowest height setting it still sat at least an inch higher then my cloth interior did.
I am 5' 11" and on my lj I had to add 1" spacers under my seat rails because I sat so lowSpeaking of headroom in the driver seat, when I had my TJ I had tons of headroom. And I remember thinking, from a designer point of view, that Jeep should consider lowering the roof on these a little to improve aero. I wonder what happened with the JL.
