Dave The Sparky
Rebuilding my CJ8 very,very slowly...
- Halifax
- UK
I can take some measurements if it would help you. I am around 1.25-1.5" offset to the drivers side. Distributor is very close to the firewall, I wanted to leave space for 2 extra cylinders. Further from the firewall will help with the fan shroud if you keep the mechanical fan. Those mounts should be easier to weld in than what i used as the height and offset appear to be fixed.
Which mounts did you go with?. According to the More blurb these will bolt in to the original engine mount chassis holes and also have the offset built in to clear the front prop but i must admit i wasnt sure where the gearbox and the back of the engine will end up.
