- Biloxi
- MS
Cleaned the header/intake:
I have had good luck using this stuff on the stainless manifold bolts. They stay tight, but come out easy:
I ended up putting two studs in the head to help install the exhaust manifold:
This PS pump bracket was fine with the old header, no go with the new stock replacement manifold:
I pulled it off, will have to cut off the top part. No big deal, the top part is useless with a 4.0 intake:
Exhaust manifold on:
The intake has these nice "notches" that align the intake with two dowels in the head, makes install/alignment easy:
My rear one has been partially broken since the day I pulled this new manifold out of it's box, but still works fine:
Intake on:
Much easier to get to the lower bolts using a "stock" style manifold vs a "header":
Intake on:
(the only spot the cancer has returned)
