- Puyallup
- WA
Rig was running fine then all of a sudden stopped getting fuel. I replaced the fuel filter and pump, blew out the line back to the tank with no luck. Decided to pull the tank and found the sending unit was toast. I installed a new sending unit, new fuel vents and rubber lines, then blew out the lines again before reinstalling the tank. I added 5 gallons of fuel to the tank and tried starting it with no luck. I hooked up an auxiliary tank to the pump to make sure it was working and it is. I've narrowed down that the fuel is not making it from the tank to the pump. Not sure where to go from here without removing the tank again. Any advice or help is appreciated.
