- Richmond
- TX
Good news / bad news. I jumpered the connector to the ignition module, and I am getting crank signal. So good that it is working, bad that the harness connectors are bad. I had to bend the spades that go into the harness connector to get a firm connection.
Next issue is no fuel in the surge tank. I think the in line filter is blocking flow from the mechanical pump. I’m gonna remake the hose without the filter to see if that fixes it.
