- Redmond
- OR
I thought on the Lokar you could shift 1st to 2nd to 1st without detents, then it step-detented in D, and could shift D to OD to D witnout detents, all while only hard detenting in P and N? Basically the same as most stock console shifters. If nothing else, it looks like the detent plate on the Lokar is pretty simple and could be manipulated with a ramp profile between 2nd and D to allow full gear range while just offering slight resistance on the ramp between 2nd and D so you at least had reference when pulling from P. Just a thought... I like the looks of the Lokar best, and the option of hard mounting and mechanically linking to the trans is nice.
The Kilduff shifter looks like a modified "his-hers" shifter from a Pontiac. Could be fun, but that's pretty steep, and I feel it would look silly anywhere but a full fabbed console.
I’ll agree the hard mounted shifter to trans is a great feature. But the Lokar is definitely not designed for “slamming gears”. IIRC the step detent for neutral was only out of N, and just a spring detent from D to N. I was using a stock Ford console shifter on Copper and finessing the upshift under full throttle was not fun. Not sure I want to lay out the bucks for the Kilduff, however I am building a custom console with park brake lever and 4x shifter on either side of the trans shifter. The Winters would be a no-brainer, I just have to figure out how to tell what gear I’m in at night.
I had seriously considered a column shifter but decided against it for the lack of performance detent.
Took me about 2 years at a new job 2nd day. Looked like it was intentional and in an odd place to even happen at
Anyway that paint looks beautiful !
