No way! He disappeared years ago and hasn’t been seen since.
I am still around just not really posting.
life kind of got in the way of Jeep stuff. Like Josh said we fina got his Jeep all together and towed it out to the house in Boulder Colorado. He is there in college.
so now to get started on a cj for the daughter for her to drive in High School.
carl
Really!Whasssupp, Carl!!
I have new plugs that will hopefully work that i will put on tomorrow. Did your friends jeep run fine at idle, but unable to “learn” to give it enough fuel?A friend just went through a bad misfire situation with a Sniper on his Scrambler. Found an article on “leaky” plug wires causing it. Did those and thought he fixed it. Ended up ripping out the Jeep wiring and starting over and reterminating the wires (had a painless harness from a PO). Now it’s fixed after that effort.
New wires* i already checked the plugs and they looked fine, if a bit leanI have new plugs that will hopefully work that i will put on tomorrow. Did your friends jeep run fine at idle, but unable to “learn” to give it enough fuel?
