Proof CBRogers finally finished a Jeep (just kidding, IAFP)
I’m his son, we’ve been working on this scrambler since I was in high school. The Jeep is an 83 that had 55k miles on it and used to be towed behind an rv. It was painted the crazy shade of yellow when we got it, we frame off rebuilt and repainted everything. Currently has a 258 with a 2100 carb.
I am still around just not really posting.
life kind of got in the way of Jeep stuff. Like Josh said we fina got his Jeep all together and towed it out to the house in Boulder Colorado. He is there in college.
so now to get started on a cj for the daughter for her to drive in High School.
carl
carl
Awesome, great to see you around here again man!! Share the daughter’s build with us!
Welcome back...well, a start, at least.
All things take longer than expected, i decided to swap to efi and hit a few stumbling points. But today, it ran and drove around the neighborhood under its own power. Hopefully i can get it sorted enough to make the Colorado trail runs
Got new tires, and already took her wheeling. Went on the bunce school rd trail in boulder towards the t33 crash site, turned around just after the hard section because it developed a misfire. Got it running good again today after reseating the spark plug wires
Apparently i did nor fix the issue. Currently it appears the holley sniper does not want to give it more fuel, even when it is at 30% duty cycle and 30 afr….
I have ordered the usb - can cable but does anyone have suggestions for tuning on the handheld in the meantime?
Im just so frustrated that it ran fine for awhile then just decided it didnt like running.
A friend just went through a bad misfire situation with a Sniper on his Scrambler. Found an article on “leaky” plug wires causing it. Did those and thought he fixed it. Ended up ripping out the Jeep wiring and starting over and reterminating the wires (had a painless harness from a PO). Now it’s fixed after that effort.
I have new plugs that will hopefully work that i will put on tomorrow. Did your friends jeep run fine at idle, but unable to “learn” to give it enough fuel?
New wires* i already checked the plugs and they looked fine, if a bit lean
