CJ7 Caroline Build
Thanks to @AdamH going to V-8 Project Caroline is getting a new, old engine. Engine is same year as Caroline... it will be nice upgrade from the empty engine bay that once had 4 cylinder from the factory.
All new seals, timing chain, water pump, etc and a little patina paint coming...
73F3FD89-5810-4B61-AAEF-EFDA094CE5B6.jpeg1DBB9453-1C09-4064-B1DD-4CEE4B7EC43B.jpeg13A93605-8F37-41E0-A600-607F57D8E437.jpeg
How many coats did you use on the firewall to get a close match? I have some of that paint but it seems more silver than blue after three coats. Looks good from an angle but not straight on
Three light coats of color and same on clear...
Look at last firewall and see middle top is old paint, it’s a touch darker from age I think, the outside a little lighter...
Looks good though. I’ll see what happens when I spray some clear.
The primer under the color might help, looks like you used the white cards that came with paint, a darker primer may give it older look... try a hinge or even just bolt
That rattle can did a good job. The right rear body mount might need some help. I had large flat washers welded in where the holes were rusted out of shape.
Thanks, it all in prep as they say... It’s little pits, seems solid... shadow in photo makes it look worse...
