CJ7 Caroline Build
rubclt
Charlotte
Got a great deal on some used BFG MT KM3 33x10.50R15 and mounted on stock white wheels... need to finish welding floors and install drive train to see how tires ride :)
rubclt
Charlotte
Thanks to @AdamH going to V-8 Project Caroline is getting a new, old engine. Engine is same year as Caroline... it will be nice upgrade from the empty engine bay that once had 4 cylinder from the factory.
All new seals, timing chain, water pump, etc and a little patina paint coming...
73F3FD89-5810-4B61-AAEF-EFDA094CE5B6.jpeg1DBB9453-1C09-4064-B1DD-4CEE4B7EC43B.jpeg13A93605-8F37-41E0-A600-607F57D8E437.jpeg
Jeep Addict
Baton Rouge
How many coats did you use on the firewall to get a close match? I have some of that paint but it seems more silver than blue after three coats. Looks good from an angle but not straight on
rubclt
Charlotte
Three light coats of color and same on clear...
Look at last firewall and see middle top is old paint, it’s a touch darker from age I think, the outside a little lighter...
Jeep Addict
Baton Rouge
Looks good though. I’ll see what happens when I spray some clear.
rubclt
Charlotte
The primer under the color might help, looks like you used the white cards that came with paint, a darker primer may give it older look... try a hinge or even just bolt
Kim Dawson
Molalla
Or
That rattle can did a good job. The right rear body mount might need some help. I had large flat washers welded in where the holes were rusted out of shape.
rubclt
Charlotte
Thanks, it all in prep as they say... It’s little pits, seems solid... shadow in photo makes it look worse...
