How many coats did you use on the firewall to get a close match? I have some of that paint but it seems more silver than blue after three coats. Looks good from an angle but not straight on
The primer under the color might help, looks like you used the white cards that came with paint, a darker primer may give it older look... try a hinge or even just boltLooks good though. I’ll see what happens when I spray some clear.
Thanks, it all in prep as they say... It’s little pits, seems solid... shadow in photo makes it look worse...That rattle can did a good job. The right rear body mount might need some help. I had large flat washers welded in where the holes were rusted out of shape.
