Gr8Dain's 4.0/aw4 swap from a 97 XJ
I wanted to get something done. So I re-bent the twin stick shifters and re-installed them. Then I cut up the Stronghold shift boot I had when I had the t-176. This will do for now.
Got the power steering pump and the clutch fan installed this afternoon. The serpentine belt that I got is too small. Not sure if I ordered the wrong one or they sent the wrong one. Will go to the local parts place and get a new one and compare sizes this time. And use my son’s employee discount.
Tomorrow I am going to remove the radiator from the grill and mock up the transmission cooler mounting. I don’t want to use the little zip tie things. So we will see what I can come up with.
Oh, I also installed my replacement starter and bashed up oil filter. Like it never happened. ?
Got the correct serpentine belt and installed it, then mounted the trans cooler. I was not planning on using the zip tie things to hold it against the radiator, but oh well, laziness prevailed today. It looks like it will work. Now the grill is “permanently” back on (hopefully).
Oh and when I was removing the radiator, I noticed that the power wire for one of the turn signal broke from the plug. I attempted a fix, but the part of thr blade that wraps around the wire was fragile and broke rather than bend. Oh well. Another part to buy.
While I am researching crossmembers, I might as well ask what others have chosen for engine skids for the 4.0. This oil pan is not as thick as the one I had on the 4.2 and is lacking that little extra protection welded to it. So I am thinking I will need to get a skid for it.
Don’t run anything besides the main crossmember :shrug:
I like the Metalcloak/Teraflex style. I put one on my TJ after I dented my pan at Rausch Creek. I bought a similar one for the motor I have in the Scram from a guy on ebay, but he's not making them any longer. You try to avoid a situation where you need that protection but it does happen.
Thanks. I will look up that style.
Since it is raining and I don’t want to lay under it in the driveway working on the fuel line today, I decided to tackle the auto shifter cover. I had to remove the auxiliary fuel and temp gauges, but it will be easy to find a new home for them. I also trimmed a little at the front and cut a hole for the shifter cable to go through, but I think it looks a little more “finished” now.
So I wanted to do something productive today. So I swapped my 33s for the 35s I picked up a while ago. Gets them off of my back porch. But now I have the 33s in my garage. Sigh
Anyway, it does not look like a lot was gained going to the 35s but I have a pic of the jack that was supporting the transfer case (was there for moral support really). So I guess the 35s do raise it up some. The chrome wheels are the 33s.
Good stuff!!
Thanks.
Need to get the fuel line done. Just ordered some parts to help with it. Still need to get some fuel injection strength hose for sections, but getting there.
More baby steps. The pcv elbows and the grommets arrived today, so after work I got them installed and put the “free to me” air cleaner assembly on. Hopefully I will be working on fuel lines this weekend.
Let’s see, what did I do today, NOT THE FUEL LINES. Instead I added the radiator hoses, the new to me evap canister, and reran the wiring for the lights and put the headlights back on. I am still waiting on parts, but should be able to tackle the fuel line stuff tomorrow.
Mounted the e2000 fuel pump and Jeep ZJ regulator/filter.
And before anyone says “the pump is supposed to be lower than the tank”, I appreciate your thoights. I don’t want it on the frame rail where it will get hit when rock crawling. I had the pump here when I tan the sniper and had zero issues. I know others who have it here as well. It is tucked up where it won’t get crushed by rocks and is accessible.
Added little fire suits to the fuel rail and injectors to prevent vapor lock. It includes a hard shield that covers the openings of the intake as well. Hope it works.
Using a sledgehammer to flatten the crossmember a bit so that the bolt holes loned up on both sides, and drilling holes for the aw4 trans support, I got the crossmember mounted. Not pretty. And with the fact that the transfer case is nicely clocked, i do believe that I will be going with a flat belly skid soon. But as of today, I no longer have a jack supporting the crossmember under the Jeep.
The fan looks awfully close to the radiator. Maybe I am paranoid due to the fact that the clutch fan on my 4.2 went through my radiator in the past.
What do you all think? Too close? I have poly mounts for the motor, so hopefully the motor won’t move much.
The fan looks a bit too close. IIRC, on my red Scrambler that now has a 4.0 with 4.2 front accessories, I used a 1979 258 fan clutch because it was about 1" shorter then the 1983 version. BUT, I am running a 4.2 water pump. I would try to get a bit more clearance if you can.
