MomoJeep
- Seattle
- WA
NEW ENGINE:
I destroyed the 4.0L head on my 258 block with HESCO MOPAR MPI conversion. I want to keep it relatively simple and not too expensive. I care about power, and I also care about gas mileage. I want to keep fuel injection.. Options:
(1) Try to throw a new 4.0L head on my block. This requires plugging water jacket holes (mine started to leak after 50k). To ensure they don't leak could be welded, but then more work is needed, hardened valve seats, etc. (the head will warp and soften). The valve seats are close to the water jacket, so it's risky.
(2) Just throw in a 4.0L. I currently have the OBD1 setup. Would have to change to OBD2 wiring? Would this have more or less power than my old setup: the 4.0L head on the 258 block...?
(3) Do a 4.0L stroker. I feel most fond of this idea because (a) I may be biased because I read about it a few times and thought it was cool. (b) I'm under the impression that it would be fairly direct bolt-in. But just like (2) above, would I need to change wiring, computer, etc?
(4) V8 (a) An LS. I don't just automatically feel the need for a V8. And I want to keep it simple, and prefer not to have to change wiring, cooling, mounts, etc. (Just spent $400 on new radiator and some cooling system upgrades or 258/4.0.). I;m not familiar with LS's and I think I prefer to stick to Jeep engines I know. (b) AMC 304 or 360. If I was to go this route I don't know if they are easily converted to fuel-injection?
I definitely appreciate any Suggestion, thoughts, advice?
