- Biloxi
- MS
Battery and starter cables installed/routed/secured. I left the positive cable off of the battery for now.
Secured the cables with a big plastic clip on the fender. I put a piece of plastic loom on the cables just for the hell of it, helps to better secure the cables inside the plastic loom clip.
The negative cable connects to the block where my finger is pointing. I routed the ground up above the oil filter to make oil filter access easier.
Put a sleeve over the starter cable to precent it from shorting out by rubbing on the fender. I will add a plastic clip down here to further secure this cable.
Trying to burn through easy to install parts, I changed the oil. It was nasty. I was going to wait until I had the engine running before I changed it for the first time, glad I did not wait, it was nasty.
The engine had a "short" oil filter installed, brand I have never heard of?
Sun was out, no rain, not too cold, so perfect weather for sitting outside and cleaning up some OEM parts before I reinstall them.
EGR valve, three under hood metal fuel lines, a metal vacuum line, and the air cleaner housing valve cover mounted base.
Dremel tool, steel wool, and time. While not "perfect", much better, and will not look out of place with all the new parts/paint.
Left is after, Right is before:
Got most of them cleaned up before the sun set.
