- Biloxi
- MS
I woke up this morning planning to get a bunch of work done, did not work out that way, but forward progress none the less.
The clutch linkage has kind of been dangling since the Jeep was shoved into the garage. I finally hung the body mounted z-bar bracket to the body, the angle is way off?
It is like the body is too low, engine too high, doesn't make since. No body lift on the Jeep, new engine and transmission mounts, so stock power train mounting, no engine lift or anything strange. Who knows.
I went ahead and took all the clutch linkage parts off to clean and inspect them. That, and it is easier to modify and play with clean parts as opposed to crusty stuff:
Of course, I got impatient with the plastic bushings, broke both of them. Grrrr.
I did find one spare bushing at my buddy Chuck's shop, will have to dig through my junk and see if I can find another. I ordered a pair off Amazon today, but with Christmas shipping times, I will be lucky to get them this year!!! Hopefully I can find another one somewhere local:
Interesting thought about the bushings: Does it even matter that they split? If I insert the two pieces of each bushing around its corresponding ball post thing, slide it in inside the z-bar, it works fine. The bushing is still a perfect tight fit around the ball, so it can't really come off, the tube keeps them tightly in place. The bushings come with two slits on the sides, that basically cut them 90% in half anyway? It would be butch to reuse the broken bushings, but I bet it would work fine.
The little ball things that the bushings ride on are still perfect, no flat spots or excessive wear on the bushing mounting surfaces:
The above picture is kind of funny. The bracket on the left, which bolts to the bell housing, and was caked in oil and grease from the leaking engine, no bad rust at all. The part on the right, that bolts to the body and was not covered in oil and grease, is pitted up pretty good. Those plastic valve covers were good for some things!!!
